Hello everybody, I have a problem with my newly installed EndeavourOs. I used the EndeavourOS_Artemis_nova_22_9.iso for my installation and selected xfce as my desktop environment. All pre-installed programs are working fine, but anything I install on top is behaving weird.
After the installation of the OS, I installed TimeShift and Ungoogled Chromium via yay and this is where the problems started to show.
- Timeshift works well most of the time, but sometimes it just quits disappears without any notice (like when restoring a snapshot it just disappears and the progress is lost).
- Ungoogled Chromium, as well as Chrome and Brave are basically unusable. They can be interacted with a little bit, but the apps flicker a lot and clicking does not always result in a change. Dragging the window around seems to cause a change in the otherwise frozen view.
- I also tried installing VS Code, which resulted in the same behaviour as 2.
Some more background information:
I installed the packages with yay -S packageName
and pacman -Syu
has no updates.
The only changes I did that I can remember before installing the new apps are:
- changing the password for my user and the
sudo
command - plugging in another display (4K) and configuring the window size to
x2
’ - adding a Bluetooth device
Heres an example: https://www.veed.io/view/87d80dfd-a023-4c55-ad1d-af5ae24f5710/showcase?sharingWidget=true
