Newbie Virtual Terminal Help
Heya guys,
I have had EndeavourOS installed for a couple of months now, running Plasma 6 with Wayland and SDDM. I wanted to try out some other WMs or DEs and tried installing them to be used on the second virtual terminal (i think tty2). My problem is I have done somthing so now when I press ctl+alt+2 I get a blank screen with just a mouse cursor. I think I have started someting automatically on tty2, see my below ps ax after a reboot. Is this something I need to worry about using my system resources, and can I stop/clear it so it doesn’t start automatically?
funkyotc@Juno ~$ ps ax | grep Xorg
   1009 tty2     Ssl+   0:02 /usr/lib/Xorg -dpi 0 -background none -seat seat0 vt2 -auth /run/sddm/xauth_dViDMM -noreset -displayfd 16
   8223 pts/1    S+     0:00 grep --color=auto Xorg
I have no problems with my tty1
Hello and welcome,
It’s because your Xorg server is on TTY2 :
Try to switch to TTY3 with Ctrl+Alt+F3.
