Hello I’m sorta new to Linux keyword “Sorta”. I currently just decide to install Endeavour on my old surface pro 3. Everything works fine like it should the issue I wrote I a bash script to check and see if the keyboard is connect or not and if it is not then it will execute onboard. the question I have is there anyway to run my script as a daemon to run ever i don’t know 5 seconds to check if the keyboard is connected ?
#!/bin/bash
if
lsusb | grep " 045e:07e2"
then
exit
else
onboard
exit
fi
Thanks again !!!
