New to Arch-based - issue with latest iso
Apologies, I did not see that it cut off some of the data after copy pastaing. It should have all data now in the original post.
Output for the other commands requested.
[pyr0cide@NixVault-Go ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 58.2G 0 disk
├─mmcblk0p1 179:1 0 300M 0 part /boot/efi
└─mmcblk0p2 179:2 0 57.9G 0 part /
mmcblk0boot0 179:8 0 4M 1 disk
mmcblk0boot1 179:16 0 4M 1 disk
mmcblk1 179:24 0 59.5G 0 disk
[pyr0cide@NixVault-Go ~]$ sudo parted -l
[sudo] password for pyr0cide:
Model: MMC hC8aP> (sd/mmc)
Disk /dev/mmcblk0: 62.5GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 62.5GB 62.2GB ext4
Error: /dev/mmcblk0boot0: unrecognised disk label
Model: Generic SD/MMC Storage Card (sd/mmc)
Disk /dev/mmcblk0boot0: 4194kB
Partition Table: unknown
Disk Flags:
Error: /dev/mmcblk1: unrecognised disk label
Model: SD SN64G (sd/mmc)
Disk /dev/mmcblk1: 63.9GB
Disk Flags:
Error: /dev/mmcblk0boot1: unrecognised disk label
Disk /dev/mmcblk0boot1: 4194kB
Disk Flags:
mmcblk0 is the internal storage of the SurfaceGo
mmcblk1 is the external SanDisk uSD card
Just FYI on the sd/mmc disks.
Update: I got it to format when using the USB-C port. Showed up as SDA instead of mmcblk1 when using a uSD usb reader.
uSD works now. Needed a workaround and still irks me that the built in uSD slot doesn’t work to format it. At this moment, however, everything, that is essential to work with it, is working.
EDIT: spoke too soon. rebooted and same issue as before…
EDIT2: I tried a couple of uSD cards last night to test to make sure that the card reader was not the issue. Turns out that it has something to do with specifically SDXC cards. A 256MB (SD) and a 16GB (SDHC) uSD worked perfectly fine, multiple reboots.
