hi, i have installed eos (Plasma) and i have to say my laptop runs smoothly like a charm. im running ist with the latest lts kernel
uname -r
5.15.32-1-lts
nevertheless i get no speed on my wifi adapter.
i have 50 for dl and 10 for ul. this is the result of speedtest:
speedtest
Retrieving speedtest.net configuration...
Testing from Vodafone Germany DSL (XX.XX.XX.XX)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by iway AG (Zurich) [178.06 km]: 27.824 ms
Testing download speed................................................................................
Download: 8.60 Mbit/s
Testing upload speed......................................................................................................
Upload: 10.33 Mbit/s
this is inxi -Fxxxza --no-host
Kernel: 5.15.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
root=UUID=5961b7b2-7842-4b64-865f-80c2f3d69c72 rw quiet
cryptdevice=UUID=7db88e27-7e6b-4d39-88e9-d6df1343edac:luks-7db88e27-7e6b-4d39-88e9-d6df1343edac
root=/dev/mapper/luks-7db88e27-7e6b-4d39-88e9-d6df1343edac loglevel=3
nowatchdog nvme_load=YES
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm:
1: LightDM v: 1.30.0 note: stopped 2: SDDM Distro: EndeavourOS
base: Arch Linux
Type: Portable System: Dell product: Studio 1558 v: A07
serial: <superuser required>
Mobo: Dell model: 0874P6 v: A07 serial: <superuser required> BIOS: Dell
v: A07 date: 06/24/2010
Battery:
ID-1: BAT0 charge: 3.6 Wh (100.0%) condition: 3.6/5.2 Wh (69.5%)
volts: 12.5 min: 11.1 model: SDI Dell type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i3 M 350 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1364 high: 1463 min/max: 933/2266 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1332 2: 1257 3: 1463
4: 1404 bogomips: 18087
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf
mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
STIBP: conditional, RSB filling
Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470] vendor: Dell
driver: radeon v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: LVDS-1 empty: HDMI-A-1,VGA-1 bus-ID: 02:00.0 chip-ID: 1002:68e0
class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 0c45:6417 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS model: AU Optronics 0x22ec built: 2009
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.15.32-1-lts LLVM 13.0.1)
v: 3.3 Mesa 22.0.0 compat-v: 3.1 direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 bus-ID: 02:00.1 chip-ID: 1002:aa68 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-lts running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.48 running: yes
Device-1: Broadcom BCM4312 802.11b/g LP-PHY
vendor: Dell Wireless 1397 WLAN Mini-Card driver: wl v: kernel modules: ssb
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:4315
class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 5000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: down mac: <filter>
Local Storage: total: 223.57 GiB used: 29.33 GiB (13.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 041 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 29.33 GiB (13.4%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-7db88e27-7e6b-4d39-88e9-d6df1343edac
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 52.0 C mobo: 0.0 C gpu: radeon temp: 63.5 C
Fan Speeds (RPM): cpu: 3796
Processes: 222 Uptime: 2h 59m wakeups: 2 Memory: 7.63 GiB
used: 2.48 GiB (32.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1146 lib: 248 Shell: Zsh v: 5.8.1
running-in: konsole inxi: 3.3.14
this is inxi -n
inxi -n
Device-1: Broadcom BCM4312 802.11b/g LP-PHY driver: wl
IF: wlan0 state: up mac: 1c:65:9d:3d:cb:69
driver: r8169
IF: enp9s0 state: down mac: f0:4d:a2:4c:d4:f1
lspci -vnn -d 14e4:
04:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
Subsystem: Dell Wireless 1397 WLAN Mini-Card [1028:000c]
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f0500000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: wl
Kernel modules: ssb, wl
i have tested all drivers and kernels in every constellation. at the moment i’m running the wl driver
any other device like my pixel with GrapheneOS has full bandwidth
maybe i have to live with this. maybe someone has already had the same problem and could help me. i would be very grateful for this.
do you need any more information?
I had already asked the question here in the german area unfortunately with no solution
thanks in advanced
