Hi there, I’m new to arch flavoured distros and I have run into an issue that leaves me puzzled.
The one way to recreate it - albeit not every time - is for me to boot / resume a linux VM in vmware, work on it, suspend and then close vmware.
What happens next is I notice loss of network connection (which I realised when steam client would take forever to load), however it’s not manifested by wifi dropping or any information from the network interfaces.
I then try to read journal to see what’s what and that is when I run sudo journalctl ... and sudo is stuck. Does not ask for password, but does not do anything. Plus I cannot ^C from it. Terminal simply stops responding.
Overall system responsiveness deteriorates until a point where I reboot it and that’s where I am hit by stop jobs, so the reboot is not possible.
That is not a good way to install on an Arch-based distro. It will cause challenges and be broken when the kernel version updates.
I would recommend fully uninstalling it using the bundle and then installing the AUR package, vmware-workstation instead. It uses a dkms module and has patches to improve compatibility.
found out that there were processes stuck in D state. Anyway - will be uninstalling vmware’s bundle and installing it from AUR and will be monitoring if the issue is back.
