I’m encoding a set of video files with ffmpeg, to do so I wrote this script which I then call on in the folder containing the files.
INPUT="$1"
for i in *.* ; do
ffmpeg -i $i -c:v libx265 -crf 20 -preset fast -c:a aac -b:a 192k "$i.mkv"
sleep 3
done
This worked for the first season/subdirectory of files, but now it cannot seem to find the files in the second subdirectory. There should be no difference, it follows the same structure e.g. /nameofshow/season 02/filename.ext
Instead it returns nameofshow: no such file or directory
, despite being called on from the directory it supposedly cannot find, but was able to do so earlier. I have not unmounted the disk or modified the structure at all.
Permissions are identical to Season 01 (which encoded without problems), and running the script with sudo does not make a difference.
This encoded fine:
/mnt/D1/TM/completed/RWBY/SEASON 01/RWBY-S01E01.mp4
This returns an error
/mnt/D1/TM/completed/RWBY/SEASON 02/RWBY-S02E01.mp4
RWBY: No such file or directory
This is the first time I’m working with ffmpeg, so I could use some advice on how to proceed. Any ideas?
