Just like that.
But make backups first.
Also just to check - did you reinstall qt5-base and rhash after creating the missing metadata placeholder files? This is an important step to fix the underlying problem.
Yes i reinstalled both, i am just not feeling confident on how exactly to do the backup for libtool tho, i am pretty much noob when it comes to fixing a broken system etc
This is definitely a âdeep endâ fix so donât worry about that.
You donât need to back up the libtool files, just overwrite them. Itâs OK in this case but --overwrite
is something to be careful of (very much so when it comes to AUR packages).
Thanks a lot, canât believe it worked !!
I can - you read the threads, worked it out, and asked for clarification where you werenât sure what to do. Perfect approach, perfect outcome.
No longer.
