I’ve been using Endeavour on a P1 Gen 3 (type 20TH, 20TJ ) Laptop (ThinkPad) - Type 20TJ for about a month now.
Ports info
Ports: 1x Mini Ethernet Connector (Convert RJ-45 by dongle); 2 USB 3.2 Gen 1 (Type A); DC-In; Smart Card Reader (Select Models); Headphone & Microphone combo Jack 3.5mm; FingerPrint Reader; Docking via Mobile Workstation Cable Dock; 2 Thunderbolt 3 (USB-C/DP/PD); HDMI 2.0; 4-in-1 Media Card Reader
Graphics: 1x NVIDIA® T1000 4GB
All this time, my built-in speakers and microphone have not worked. I have external speakers connection to my usb-c dock with 3.5mm jack. For my mic I’m currently using the mic of my wired earbuds that are connected to the laptop’s 3.5mm jack port.
The built-in speakers and mic worked fine on windows. Now, the speakers and mic do not show up in the KDE plasma sound panel.
inxi -Fxxc0z
Kernel: 6.6.52-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 20TJS02U00 v: ThinkPad P1 Gen 3
Mobo: LENOVO model: 20TJS02U00 v: 0B98417 WIN serial: <superuser required>
part-nu: LENOVO_MT_20TJ_BU_Think_FM_ThinkPad P1 Gen 3 UEFI: LENOVO
v: N2VET48W (1.33 ) date: 06/07/2024
Battery:
ID-1: BAT0 charge: 46.7 Wh (61.0%) condition: 76.6/80.0 Wh (95.7%)
volts: 15.7 min: 15.4 model: Celxpert 5B10X19050 serial: <filter>
status: not charging
Device-1: hid-CC2048200CGJ5R9A1-battery model: Apple Inc. Magic Trackpad 2
serial: N/A charge: N/A status: discharging
Info: 6-core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake rev: 2 cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 800 high: 804 min/max: 800/5000 cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 801 8: 800 9: 800 10: 800 11: 800 12: 804
bogomips: 62431
Device-1: NVIDIA TU117GLM [Quadro T1000 Mobile] vendor: Lenovo
driver: nvidia v: 560.35.03 arch: Turing pcie: speed: 8 GT/s lanes: 16
ports: active: none off: DP-1, DP-3, HDMI-A-1, eDP-1 empty: DP-2
bus-ID: 01:00.0 chip-ID: 10de:1fb9
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-8:4 chip-ID: 13d3:56bb
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 7920x4320 s-dpi: 78
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,3-2
model: LG (GoldStar) ULTRAFINE res: 3840x2160 dpi: 140 diag: 806mm (31.7")
Monitor-2: not-matched mapped: DP-1.2 pos: 2-3 res: 2160x3840 dpi: 140
diag: 800mm (31.48")
Monitor-3: not-matched mapped: DP-2 pos: 4-1 res: 1920x1080 dpi: 142
diag: 395mm (15.55")
Monitor-4: not-matched mapped: HDMI-0 pos: 1-2 res: 3840x2160 dpi: 140
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: swrast
gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: Quadro T1000 with Max-Q
Design/PCIe/SSE2
API: Vulkan v: 1.3.295 surfaces: xcb,xlib device: 0 type: discrete-gpu
driver: nvidia device-ID: 10de:1fb9
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-3: Realtek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 5-1.3.4:5
chip-ID: 0bda:49a7
API: ALSA v: k6.6.52-1-lts status: kernel-api
Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 bus-ID: 6-1.3.3:4 chip-ID: 0bda:8153
IF: enp47s0u1u3u3 state: down mac: <filter>
IF-ID-1: br-ceb775794c7c state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-14:7 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: disabled
Local Storage: total: 2.29 TiB used: 237.67 GiB (10.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 47.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: MZVLB512HBJQ-000L7
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 27.9 C
ID-1: / size: 896.54 GiB used: 232.22 GiB (25.9%) fs: btrfs
dev: /dev/nvme0n1p4
ID-2: /boot/efi size: 1022 MiB used: 588 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 896.54 GiB used: 232.22 GiB (25.9%) fs: btrfs
dev: /dev/nvme0n1p4
ID-4: /var/log size: 896.54 GiB used: 232.22 GiB (25.9%) fs: btrfs
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 68.93 GiB used: 5.45 GiB (7.9%)
priority: -2 dev: /dev/nvme0n1p3
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (rpm): fan-1: 3462 fan-2: 3106
Memory: total: 64 GiB note: est. available: 62.66 GiB
used: 17.01 GiB (27.1%)
Processes: 466 Power: uptime: 5h 54m wakeups: 0 Init: systemd v: 256
default: graphical
Packages: pm: pacman pkgs: 1208 Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: fish v: 3.7.1 running-in: kitty inxi: 3.3.35
Could someone point me in the right direction regarding what I should do here? Thanks in advance!
xircon
September 22, 2024, 6:51pm
2
What happens if you take the dock out of the equation?
Thanks for your reply!
I tested without the dock, but it didn’t make a difference. What did help though, was unplugging the headphones that are connected via the laptop’s 3.5mm jack.
Hub disconnected:
inxi -Fxxc0z
Battery:
Speed (MHz): avg: 800 high: 801 min/max: 800/5000 cores: 1: 800 2: 800
3: 800 4: 801 5: 800 6: 800 7: 800 8: 801 9: 800 10: 800 11: 800 12: 800
bogomips: 62431
driver: nvidia v: 560.35.03 arch: Turing pcie: speed: 5 GT/s lanes: 16
ports: active: none off: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 01:00.0
chip-ID: 10de:1fb9
Screen-1: 0 s-res: 5760x2160 s-dpi: 137
Monitor-1: not-matched mapped: DP-2 pos: primary,left res: 1920x1080
dpi: 142 diag: 395mm (15.55")
Monitor-2: not-matched mapped: HDMI-0 pos: right res: 3840x2160 dpi: 140
Design/PCIe/SSE2
Bluetooth:
speed: 12 Mb/s lanes: 1 bus-ID: 1-14:6 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 2.29 TiB used: 232.73 GiB (9.9%)
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 38.9 C
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 43.9 C
ID-1: / size: 896.54 GiB used: 232.71 GiB (26.0%) fs: btrfs
dev: /dev/nvme0n1p4
dev: /dev/nvme0n1p1
ID-3: /home size: 896.54 GiB used: 232.71 GiB (26.0%) fs: btrfs
dev: /dev/nvme0n1p4
ID-4: /var/log size: 896.54 GiB used: 232.71 GiB (26.0%) fs: btrfs
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 68.93 GiB used: 23 MiB (0.0%)
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A
Memory: total: 64 GiB note: est. available: 62.66 GiB used: 6.8 GiB (10.9%)
Processes: 389 Power: uptime: 14m wakeups: 0 Init: systemd v: 256
default: graphical
Headphones disconnected:
inxi -Fxxc0z
Battery:
Speed (MHz): avg: 804 high: 824 min/max: 800/5000 cores: 1: 808 2: 800
3: 800 4: 824 5: 800 6: 800 7: 800 8: 800 9: 819 10: 800 11: 800 12: 800
bogomips: 62431
Design/PCIe/SSE2
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-1.3.4:5
chip-ID: 0bda:49a7
rev: 3.0 speed: 5 Gb/s lanes: 1 bus-ID: 4-1.3.3:4 chip-ID: 0bda:8153
IF: enp9s0u1u3u3 state: down mac: <filter>
Bluetooth:
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 47.9 C
ID-1: / size: 896.54 GiB used: 232.73 GiB (26.0%) fs: btrfs
dev: /dev/nvme0n1p4
dev: /dev/nvme0n1p1
ID-3: /home size: 896.54 GiB used: 232.73 GiB (26.0%) fs: btrfs
dev: /dev/nvme0n1p4
ID-4: /var/log size: 896.54 GiB used: 232.73 GiB (26.0%) fs: btrfs
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 68.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 49.0 C pch: 72.0 C mobo: N/A gpu: nvidia
temp: 50 C
Fan Speeds (rpm): fan-1: 3460 fan-2: 3109
Memory: total: 64 GiB note: est. available: 62.66 GiB used: 6.04 GiB (9.6%)
Processes: 403 Power: uptime: 2m wakeups: 0 Init: systemd v: 256
default: graphical
Given that the speakers do work when the headphones are unplugged, is there a way I can also use them while they’re plugged in? I was able to do this on windows.
xircon
September 23, 2024, 9:59am
4
Thought it was general accepted behavior that plugging headphones in muted the speakers? Does on all my machines, Linux and windows.
Plugging in my headphones on windows just switches to that output, but I can freely switch back to built-in speakers if I want to; the speaker output option does not disappear.
So is this expected behaviour on Linux then?
