Need help reinstalling/recovering after interrupted update
First post, bit of a noob, so let me know if there’s any more information you need. Googling these specific errors yield no useful results.
System totally broken after I interrupted a full system upgrade. Lesson learned, but I’m struggling to recover or repair my system. The file system seems to be intact but it doesn’t show up in the boot menu. It was installed via systemd, if that is relevant.
I’ve used chroot to do a full system upgrade (pacman -Syuu) and it succeeded, I think (tells me there’s nothing more to do). I then tried reinstall-kernels and it spits this out:
[liveuser@eos-2026.01.12 ~]$ sudo mount /dev/nvme0n1p2 /mnt
[liveuser@eos-2026.01.12 ~]$ sudo mount /dev/nvme0n1p1 /mnt/efi
[liveuser@eos-2026.01.12 ~]$ sudo arch-chroot /mnt
[root@EndeavourOS /]# reinstall-kernels
Installing kernel 7.0.3-arch1-2
dracut-install: ERROR: could not locate dependency libgcc_s.so.1 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_mymachines.so.2
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_mymachines.so.2
dracut-install: ERROR: could not locate dependency ld-linux.so.2 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_mymachines.so.2
dracut-install: ERROR: could not locate dependency libm.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_systemd.so.2
dracut-install: ERROR: could not locate dependency libgcc_s.so.1 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_systemd.so.2
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_systemd.so.2
dracut-install: ERROR: could not locate dependency ld-linux.so.2 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_systemd.so.2
dracut-install: ERROR: could not locate dependency libffi.so.8 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libp11-kit.so.0.4.8
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libp11-kit.so.0.4.8
dracut-install: ERROR: could not locate dependency ld-linux.so.2 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libp11-kit.so.0.4.8
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libtasn1.so.6.6.5
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libffi.so.8.2.0
dracut-install: ERROR: could not locate dependency libgcc_s.so.1 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_myhostname.so.2
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_myhostname.so.2
dracut-install: ERROR: could not locate dependency ld-linux.so.2 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_myhostname.so.2
dracut-install: ERROR: could not locate dependency libgcc_s.so.1 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libudev.so.1.7.13
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libudev.so.1.7.13
dracut-install: ERROR: could not locate dependency ld-linux.so.2 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libudev.so.1.7.13
dracut-install: ERROR: could not locate dependency libm.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_resolve.so.2
dracut-install: ERROR: could not locate dependency libgcc_s.so.1 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_resolve.so.2
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_resolve.so.2
dracut-install: ERROR: could not locate dependency ld-linux.so.2 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libnss_resolve.so.2
dracut-install: ERROR: could not locate dependency libc.so.6 requested by /var/tmp/dracut.dWgNt2j/initramfs/usr/lib32/libz.so.1.3.2
dracut[F]: Resolving executable dependencies failed
/usr/lib/kernel/install.d/50-dracut-fallback.install failed with exit status 1.
I figured my system is toast and I need to just reinstall, so I tried to ssh/sftp into the live boot and it tells me I need a password. There is no password that I am aware of, so I can’t do that. I only have one USB slot so I can’t plug something else in to extract the important files.
Doing either of these things will solve my issue, but obviously a system recover would be preferred.
Welcome to the community @BetaSigmaOmega :waving_hand::smiley: :enos_flag:
Within the arch-chroot environment, try re-installing base-devel, which some of those libs look to be a part of. gcc, a dependency of base-devel for example was recently updated, so it was likely part of that failed update:
pacman --force -S base-devel
Edit: removed because --force has been deprecated. The correct command as @BetaSigmaOmega noted should have been:
sudo pacman -S base-devel --overwrite '*'
That’s a pretty integral package and that’s a relatively small step. Depending on how severe things are, you may need to force re-install all your packages.
“–force” isn’t an option. Apparently you are supposed to use "–overwrite ‘*’ " instead. Doing so gives me this monstrosity of an error message:
[root@EndeavourOS /]# sudo pacman --force -S base-devel
error: invalid option '--force'
[root@EndeavourOS /]# sudo pacman -S base-devel --overwrite '*'
warning: base-devel-1-2 is up to date -- reinstalling
resolving dependencies...
error: could not open file /var/lib/pacman/local/lib32-llvm-libs-1:22.1.3-1/desc: No such file or directory
Package (1)      Old Version  New Version  Net Change
core/base-devel  1-2          1-2            0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                                     [------------------------------------] 100%
(1/1) checking package integrity                                   [------------------------------------] 100%
(1/1) loading package files                                        [------------------------------------] 100%
(1/1) checking for file conflicts                                  [------------------------------------] 100%
:: Processing package changes...
(1/1) reinstalling base-devel                                      [------------------------------------] 100%
ldconfig: File /usr/lib/libkwin.so is empty, not checked.
ldconfig: File /usr/lib/libKF6PeopleWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libPlasmaActivitiesStats.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libgwenviewlib.so.4.97.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DParticleEffects.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libweather_ion.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib/libplasmaweatherdata.so is empty, not checked.
ldconfig: File /usr/lib/libkateprivate.so.26.04.0 is empty, not checked.
ldconfig: File /usr/lib/libkfontinstui.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libipq.so is empty, not checked.
ldconfig: File /usr/lib/libQt6SensorsQuick.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_ximgproc.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_cvv.so.413 is empty, not checked.
ldconfig: File /usr/lib/libPlasma5Support.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_highgui.so is empty, not checked.
ldconfig: File /usr/lib/libQuickChartsControls.so.1 is empty, not checked.
ldconfig: File /usr/lib/libopencv_img_hash.so.413 is empty, not checked.
ldconfig: File /usr/lib/libtbbbind_2_5.so.3.18 is empty, not checked.
ldconfig: File /usr/lib/ld-linux.so.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DIblBaker.so is empty, not checked.
ldconfig: File /usr/lib/libQt6WebSockets.so is empty, not checked.
ldconfig: File /usr/lib/libXrApiLayer_api_dump.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_text.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_face.so.413 is empty, not checked.
ldconfig: File /usr/lib/libQt6HunspellInputMethod.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_tracking.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libMpvQt.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_saliency.so.413 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DXr.so is empty, not checked.
ldconfig: File /usr/lib/libKQuickImageEditor.so.1 is empty, not checked.
ldconfig: File /usr/lib/libKGlobalAccelD.so.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DHelpers.so is empty, not checked.
ldconfig: File /usr/lib/libKScreenLocker.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libopencv_ximgproc.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKF6PrisonScanner.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Nfc.so is empty, not checked.
ldconfig: File /usr/lib/libqaccessibilityclient-qt6.so.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_calib3d.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libjasper.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Nfc.so.6 is empty, not checked.
ldconfig: File /usr/lib/libkfontinstui.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_xfeatures2d.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libqaccessibilityclient-qt6.so.0.6.0 is empty, not checked.
ldconfig: File /usr/lib/libMpvQt.so.2 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSystemStats.so is empty, not checked.
ldconfig: File /usr/lib/libkonsoleprivate.so.26.04.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_core.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQuickCharts.so.1 is empty, not checked.
ldconfig: File /usr/lib/libopencv_rapid.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_fuzzy.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_ccalib.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_rgbd.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_ximgproc.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_intensity_transform.so.413 is empty, not checked.
ldconfig: File /usr/lib/libbatterycontrol.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libopencv_signal.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKF6PrisonScanner.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libklipper.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_quality.so.413 is empty, not checked.
ldconfig: File /usr/lib/libQMobipocket6.so.3.0.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DRuntimeRender.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_structured_light.so is empty, not checked.
ldconfig: File /usr/lib/libip4tc.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTimelineBlendTrees.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_shape.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_imgcodecs.so is empty, not checked.
ldconfig: File /usr/lib/libKF6Contacts.so.6 is empty, not checked.
ldconfig: File /usr/lib/libXpm.so.4.11.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6UnitConversion.so.6 is empty, not checked.
ldconfig: File /usr/lib/libPlasmaActivitiesStats.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_fuzzy.so is empty, not checked.
ldconfig: File /usr/lib/libPlasma5Support.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_flann.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKF6PeopleBackend.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libKWaylandClient.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libplasma-geolocation-interface.so is empty, not checked.
ldconfig: File /usr/lib/libtbbbind_2_5.so.3 is empty, not checked.
ldconfig: File /usr/lib/libplasmaweatherdata.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libXrApiLayer_best_practices_validation.so is empty, not checked.
ldconfig: File /usr/lib/libprocesscore.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_hdf.so is empty, not checked.
ldconfig: File /usr/lib/libcdio_paranoia.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKNightTime.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dnn.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKF6ScreenDpms.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_rgbd.so.413 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DGlslParser.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6PurposeWidgets.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_img_hash.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DAssetImport.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_flann.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_ml.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_text.so.413 is empty, not checked.
ldconfig: File /usr/lib/libXaw7.so.7 is empty, not checked.
ldconfig: File /usr/lib/libnetfilter_conntrack.so.3.8.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_datasets.so.413 is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libkwin.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dnn_superres.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libprocesscore.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libXpm.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_videoio.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_core.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_dpm.so is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectcore.so.26.04.0 is empty, not checked.
ldconfig: File /usr/lib/libtbbmalloc_proxy.so.2.18 is empty, not checked.
ldconfig: File /usr/lib/libssc.so.2 is empty, not checked.
ldconfig: File /usr/lib/libluajit-5.1.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_datasets.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6PeopleBackend.so is empty, not checked.
ldconfig: File /usr/lib/libip4tc.so.2 is empty, not checked.
ldconfig: File /usr/lib/libopencv_ccalib.so.413 is empty, not checked.
ldconfig: File /usr/lib/libbatterycontrol.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_ml.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_features2d.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_bgsegm.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_img_hash.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_bioinspired.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_flann.so is empty, not checked.
ldconfig: File /usr/lib/libkaccounts6.so.2 is empty, not checked.
ldconfig: File /usr/lib/libopencv_face.so is empty, not checked.
ldconfig: File /usr/lib/libkmpris.so.6 is empty, not checked.
ldconfig: File /usr/lib/libtaskmanager.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libopencv_gapi.so is empty, not checked.
ldconfig: File /usr/lib/libxtables.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_stereo.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_wechat_qrcode.so.413 is empty, not checked.
ldconfig: File /usr/lib/libkcmkwincommon-x11.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libKF6Screen.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libopencv_ml.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQuickChartsControls.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_mcc.so is empty, not checked.
ldconfig: File /usr/lib/libklipper.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_saliency.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_rapid.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Location.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_photo.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DAssetUtils.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensorFaces.so.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6VirtualKeyboardSettings.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DParticleEffects.so is empty, not checked.
ldconfig: File /usr/lib/libcdio_cdda.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_videostab.so is empty, not checked.
ldconfig: File /usr/lib/libtaskmanager.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DIblBaker.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6UnitConversion.so is empty, not checked.
ldconfig: File /usr/lib/libKF6Holidays.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libtbbmalloc.so.2.18 is empty, not checked.
ldconfig: File /usr/lib/libQt6WebSockets.so.6 is empty, not checked.
ldconfig: File /usr/lib/libipq.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dpm.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libtbbmalloc.so is empty, not checked.
ldconfig: File /usr/lib/libplasma-geolocation-interface.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libKF6Runner.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6Prison.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libnotificationmanager.so.1 is empty, not checked.
ldconfig: File /usr/lib/libopencv_text.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_alphamat.so is empty, not checked.
ldconfig: File /usr/lib/libkmpris.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libXaw6.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopenxr_loader.so.1 is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DXr.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_reg.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libhavege.so.2 is empty, not checked.
ldconfig: File /usr/lib/libtbbmalloc_proxy.so is empty, not checked.
ldconfig: File /usr/lib/libPlasma5Support.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libkworkspace6.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libplasmaweatherion.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libplasmapotdprovidercore.so is empty, not checked.
ldconfig: File /usr/lib/libKF6PeopleBackend.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_cvv.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Bluetooth.so is empty, not checked.
ldconfig: File /usr/lib/libtbbmalloc_proxy.so.2 is empty, not checked.
ldconfig: File /usr/lib/libtbb.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_quality.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_features2d.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_phase_unwrapping.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_structured_light.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_signal.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libklookandfeel.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKPipeWireRecord.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensors.so.2 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dnn_objdetect.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKF6PurposeWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_saliency.so is empty, not checked.
ldconfig: File /usr/lib/libqt6keychain.so.0.16.0 is empty, not checked.
ldconfig: File /usr/lib/libopenxr_loader.so is empty, not checked.
ldconfig: File /usr/lib/libKF6NotifyConfig.so.6 is empty, not checked.
ldconfig: File /usr/lib/libip4tc.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6Purpose.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensorFaces.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libopencv_imgproc.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_wechat_qrcode.so is empty, not checked.
ldconfig: File /usr/lib/libjasper.so.7 is empty, not checked.
ldconfig: File /usr/lib/libprocesscore.so.10 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DHelpersImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DRuntimeRender.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_hfs.so is empty, not checked.
ldconfig: File /usr/lib/libverdict.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_photo.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_aruco.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_imgcodecs.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libkdsingleapplication-qt6.so.1.2.1 is empty, not checked.
ldconfig: File /usr/lib/libopencv_stereo.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKQuickImageEditor.so is empty, not checked.
ldconfig: File /usr/lib/libXaw7.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DHelpersImpl.so is empty, not checked.
ldconfig: File /usr/lib/libKF6Purpose.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6WebSockets.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libip6tc.so.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6VirtualKeyboardQml.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_bgsegm.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libkwin-x11.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_objdetect.so.413 is empty, not checked.
ldconfig: File /usr/lib/libkwin-x11.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6VirtualKeyboard.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DEffects.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6People.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libfyaml.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_freetype.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_xfeatures2d.so.413 is empty, not checked.
ldconfig: File /usr/lib/libQuickCharts.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libKPipeWireRecord.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libuchardet.so.0.0.8 is empty, not checked.
ldconfig: File /usr/lib/libopencv_viz.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_calib3d.so is empty, not checked.
ldconfig: File /usr/lib/libluajit-5.1.so.2 is empty, not checked.
ldconfig: File /usr/lib/libjasper.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib/libPlasmaActivitiesStats.so.1 is empty, not checked.
ldconfig: File /usr/lib/libopencv_video.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6PeopleWidgets.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_phase_unwrapping.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKPipeWire.so.6 is empty, not checked.
ldconfig: File /usr/lib/libkdsingleapplication-qt6.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_bioinspired.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_objdetect.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_objdetect.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_dnn.so is empty, not checked.
ldconfig: File /usr/lib/libQt6HunspellInputMethod.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_signal.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_videostab.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6PeopleWidgets.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6StatusNotifierItem.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libkworkspace6.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_shape.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DParticleEffects.so.6 is empty, not checked.
ldconfig: File /usr/lib/libirml.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_xobjdetect.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_xphoto.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_aruco.so.413 is empty, not checked.
ldconfig: File /usr/lib/libMpvQt.so.1.1.1 is empty, not checked.
ldconfig: File /usr/lib/libXaw6.so.6.0.1 is empty, not checked.
ldconfig: File /usr/lib/libQMobipocket6.so is empty, not checked.
ldconfig: File /usr/lib/libplasmapotdprovidercore.so.2 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dnn_objdetect.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_video.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKF6UnitConversion.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_line_descriptor.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3D.so is empty, not checked.
ldconfig: File /usr/lib/libXaw7.so is empty, not checked.
ldconfig: File /usr/lib/libverdict.so.1.4 is empty, not checked.
ldconfig: File /usr/lib/libopencv_superres.so.413 is empty, not checked.
ldconfig: File /usr/lib/libklookandfeel.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libKScreenLocker.so is empty, not checked.
ldconfig: File /usr/lib/libqalculate.so.23 is empty, not checked.
ldconfig: File /usr/lib/libXpm.so.4 is empty, not checked.
ldconfig: File /usr/lib/libweather_ion.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_bgsegm.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_plot.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libkrdb.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DEffects.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQuickChartsControls.so.6.25.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTimeline.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_surface_matching.so is empty, not checked.
ldconfig: File /usr/lib/libQt6VirtualKeyboardSettings.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6PurposeWidgets.so.6 is empty, not checked.
ldconfig: File /usr/lib/libXaw.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Nfc.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6PrisonScanner.so is empty, not checked.
ldconfig: File /usr/lib/libKF6Screen.so.8 is empty, not checked.
ldconfig: File /usr/lib/libqt6keychain.so is empty, not checked.
ldconfig: File /usr/lib/libQuickCharts.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_quality.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6ScreenDpms.so.8 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dnn_superres.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_rapid.so.413 is empty, not checked.
ldconfig: File /usr/lib/libnetfilter_conntrack.so is empty, not checked.
ldconfig: File /usr/lib/libKF6StatusNotifierItem.so is empty, not checked.
ldconfig: File /usr/lib/libKPipeWireDmaBuf.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dnn_superres.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_viz.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DHelpers.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_imgcodecs.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_stitching.so is empty, not checked.
ldconfig: File /usr/lib/libkcmkwincommon.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKNightTime.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_calib3d.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_stereo.so is empty, not checked.
ldconfig: File /usr/lib/libXrApiLayer_core_validation.so is empty, not checked.
ldconfig: File /usr/lib/libKGlobalAccelD.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libQt6Bluetooth.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_structured_light.so.413 is empty, not checked.
ldconfig: File /usr/lib/libQt6VirtualKeyboard.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKPipeWireDmaBuf.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libKRdp.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_viz.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_freetype.so.413 is empty, not checked.
ldconfig: File /usr/lib/libfyaml.so.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTimeline.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensors.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_bioinspired.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_dpm.so.413 is empty, not checked.
ldconfig: File /usr/lib/libQt6VirtualKeyboardSettings.so.6 is empty, not checked.
ldconfig: File /usr/lib/libqalculate.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_shape.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_mcc.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTimelineBlendTrees.so is empty, not checked.
ldconfig: File /usr/lib/libipq.so.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_superres.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libkaccounts6.so.26.04.0 is empty, not checked.
ldconfig: File /usr/lib/libopencv_optflow.so.413 is empty, not checked.
ldconfig: File /usr/lib/libXaw.so.7 is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectcore.so.26 is empty, not checked.
ldconfig: File /usr/lib/libverdict.so.1.4.5 is empty, not checked.
ldconfig: File /usr/lib/libkfontinst.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libKRdp.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTimeline.so is empty, not checked.
ldconfig: File /usr/lib/libKRdp.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_phase_unwrapping.so is empty, not checked.
ldconfig: File /usr/lib/libxtables.so.12.7.0 is empty, not checked.
ldconfig: File /usr/lib/libkfontinstui.so is empty, not checked.
ldconfig: File /usr/lib/libnotificationmanager.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libcdio_paranoia.so.2 is empty, not checked.
ldconfig: File /usr/lib/libopencv_rgbd.so is empty, not checked.
ldconfig: File /usr/lib/libKQuickImageEditor.so.0.6.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3D.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DUtils.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DUtils.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DAssetUtils.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DGlslParser.so is empty, not checked.
ldconfig: File /usr/lib/libcdio_cdda.so.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6HunspellInputMethod.so is empty, not checked.
ldconfig: File /usr/lib/libkactivitymanagerd_plugin.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_xfeatures2d.so is empty, not checked.
ldconfig: File /usr/lib/libQMobipocket6.so.3 is empty, not checked.
ldconfig: File /usr/lib/libkwin.so.6.6.4 is empty, not checked.
ldconfig: File /usr/lib/libQt6VirtualKeyboard.so is empty, not checked.
ldconfig: File /usr/lib/libopencv_hfs.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DRuntimeRender.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_highgui.so.4.13.0 is empty, not checked.
ldconfig: File /usr/lib/libkaccounts6.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Sensors.so.6.11.0 is empty, not checked.
ldconfig: File /usr/lib/libcdio_cdda.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick3DIblBaker.so.6 is empty, not checked.
ldconfig: File /usr/lib/libopencv_photo.so.413 is empty, not checked.
ldconfig: File /usr/lib/libopencv_hdf.so.413 is empty, not checked.
ldconfig: File /usr/lib/libKF6Su.so is empty, not checked.
error: command terminated by signal 11: Segmentation fault
(1/1) Checking which packages need to be rebuilt
fatal library error, lookup self```
Then you need to invest in a USB hub so you can have the extra ports when needed.
what packages does pacman show as installed?
Ah sorry about the --force argument, it turns out that was removed.
With respect to those errors, that would seem to confirm that the interrupted upgrade corrupted things and this --overwrite step is how you’d address that.
Step through these commands carefully, and feel free to double check them first. I’ve tested them here before sharing.
To re-install your explicitly installed packages:
sudo pacman -S --overwrite '*' $(pacman -Qneq)
To re-install your installed dependencies:
sudo pacman -S --asdeps --overwrite '*' $(pacman -Qndq)
Then to re-install your AUR packages:
yay -S --overwrite '*' $(yay -Qmq)
It should be noted that some might view this as a less than ideal solution, and advise for a re-install.
At the very least though, hopefully this helps you get back on your feet, so you might do that later.
No dice. :confused: The first command for explicit packages fails fairly unremarkably due to invalid or corrupt packages. The second one also fails, though it seems like we’re getting closer to the problem. The full log goes over double the character limit (and I can’t upload the text file) but both Fakeroot and glibc fail to install for what looks to me like identical reasons. Here’s the error from attempting to install glibc:
reinstalling glibc...
Generating locales...
  en_US.UTF-8... done
Generation complete.
ldconfig: File /usr/lib/libdjvulibre.so is empty, not checked.
ldconfig: File /usr/lib/libcppdap.so is empty, not checked.
ldconfig: File /usr/lib/libini_config.so.8 is empty, not checked.
ldconfig: File /usr/lib/libeditorconfig.so.0.12.11 is empty, not checked.
ldconfig: File /usr/lib/libuv.so.1 is empty, not checked.
ldconfig: File /usr/lib/libefisec.so.1.39 is empty, not checked.
ldconfig: File /usr/lib/libmarkdown.so.3 is empty, not checked.
ldconfig: File /usr/lib/libguile-3.0.so is empty, not checked.
ldconfig: File /usr/lib/libconfuse.so is empty, not checked.
ldconfig: File /usr/lib/libddcutil.so.5 is empty, not checked.
ldconfig: File /usr/lib/librhash.so.1.4.6 is empty, not checked.
ldconfig: File /usr/lib/libgc.so is empty, not checked.
ldconfig: File /usr/lib/libgccpp.so is empty, not checked.
ldconfig: File /usr/lib/libuv.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libell.so is empty, not checked.
ldconfig: File /usr/lib/libddcutil.so is empty, not checked.
ldconfig: File /usr/lib/libcord.so.1 is empty, not checked.
ldconfig: File /usr/lib/libell.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdjvulibre.so.21.8.0 is empty, not checked.
ldconfig: File /usr/lib/libi2c.so.0.1.1 is empty, not checked.
ldconfig: File /usr/lib/libXrandr.so.2.2.0 is empty, not checked.
ldconfig: File /usr/lib/libgctba.so.1 is empty, not checked.
ldconfig: File /usr/lib/libgctba.so is empty, not checked.
ldconfig: File /usr/lib/libclang.so.22.1 is empty, not checked.
ldconfig: File /usr/lib/libguile-3.0.so.1 is empty, not checked.
ldconfig: File /usr/lib/libini_config.so is empty, not checked.
ldconfig: File /usr/lib/libXrandr.so.2 is empty, not checked.
ldconfig: File /usr/lib/libgccpp.so.1 is empty, not checked.
ldconfig: File /usr/lib/libeditorconfig.so is empty, not checked.
ldconfig: File /usr/lib/libclang-cpp.so.21.1 is empty, not checked.
ldconfig: File /usr/lib/libconfuse.so.2.1.0 is empty, not checked.
ldconfig: File /usr/lib/libgccpp.so.1.5.0 is empty, not checked.
ldconfig: File /usr/lib/libXrandr.so is empty, not checked.
ldconfig: File /usr/lib/libmarkdown.so.3.0.0 is empty, not checked.
ldconfig: File /usr/lib/libefiboot.so is empty, not checked.
ldconfig: File /usr/lib/libclang.so is empty, not checked.
ldconfig: File /usr/lib/libgc.so.1 is empty, not checked.
ldconfig: File /usr/lib/libi2c.so.0 is empty, not checked.
ldconfig: File /usr/lib/libell.so.0.0.2 is empty, not checked.
ldconfig: File /usr/lib/libconfuse.so.2 is empty, not checked.
ldconfig: File /usr/lib/libefisec.so is empty, not checked.
ldconfig: File /usr/lib/libguile-3.0.so.1.7.1 is empty, not checked.
ldconfig: File /usr/lib/libeditorconfig.so.0 is empty, not checked.
ldconfig: File /usr/lib/libefivar.so.1 is empty, not checked.
ldconfig: File /usr/lib/libjsoncpp.so.26 is empty, not checked.
ldconfig: File /usr/lib/libuv.so is empty, not checked.
/tmp/alpm_1EF552/.INSTALL: line 1: 12815 Segmentation fault         (core dumped) ldconfig -r .
On the flip side, I did manage to find a USB-A to C adapter so I could plug in an external hard drive and extract the files I wanted to back up. I don’t mind reinstalling now, but if there’s still more I can try I would be willing to give it a go.
P.S. I had no packages installed from the AUR so I skipped that one.
It’s a shame it wasn’t going to be fairly easy to resolve.
I’d suggest taking that backup, and re-installing fresh. It’s a bit of pain now, but it’s better to be running with a solid base, rather than wondering if every future issue is somehow related to the update saga.
please note for future references you can use eos-sendlog and post the url here so the logs can be viewed.
:backhand_index_pointing_up:
