I installed endeavouros a while ago and i have now decided i want to switch to worm for my wm
but when ever i try to start it it just gives a black screen
extra info
i installed it through pacman and i have a rc file and a sxhkdrc file in my config folder
and i have tried starting it through my display manager and startx
i have a nvidia gpu (gtx 1080 Proprietary drivers)
my ~/.config/worm/rc is just the example one from github
and when execute worm from terminal it give me
15:39:30 | INFO | wm.nim:35 | Opened display
X Error of failed request: BadAccess (attempt to access private resource denied)
Major opcode of failed request: 2 (X_ChangeWindowAttributes)
Serial number of failed request: 23
Current serial number in output stream: 24
ok, that is pretty expected. actually you should get a black screen, because https://github.com/codic12/worm/blob/main/examples/rc (which I didn’t write) sets the wallpaper using nitrogen --restore, you can install/set up nitrogen or use something like feh. Also sxhkdrc in that case is in ~/.config/worm/sxhkdrc, not ~/.config/sxhkd/sxhkdrc; and you also need to have that polybar configuration to start the polybar (or make your own / use another bar.)
oh no i probably should marked this as solved bit yeah codic12 solution was correct it nitrogen not working resulting in no wallpaper should have realized this but im not very smart
Go to @codic12 's post, click on the three horizontal dots next to Reply.
then click on “Solutions”
This will mark this Topic as solved, and put codec12’s post in the Original Post.
This allows anyone having the same problem look at this Topic’s solution right from the git go and see if it applies to their situation.
