Need help in using KTimer for Pomodoro Technique
Due to some unforeseen reasons I have been advised by my medical practitioner to follow the Pomodoro Technique. Basically it is 30 minutes of work and then 5 minutes away from the workstation doing some stretching or walking or looking away from the screen.
So I setup the same with KDE Ktimer as can be seen below
The problem the two tasks do not loop sequentially. i.e. the First 30 minute counter is not followed by 5 minute counter and then the cycle repeats.
How do I get it to work? I have to manually enable the first counter and then the 2nd counter and then repeat it.
I am on KDE.
why not just make a simple script to use the notification deamon and set it up with a systemd timer?
May I suggest using a dedicated pomodoro app, there are dozens out there, see e.g.: https://flathub.org/en/apps/search?q=pomodoro
Personally I like the Fokus widget: https://store.kde.org/p/1308861/
Will Plasma 5 widgets work with Plasma 6?
Notification Deamon? Is there some documentation that I can refer to?
It has to cycle between 30 minutes - 5 minutes - 30 minutes - 5 minutes — and so on.
My bad, just posted the first link from the search engine without looking. This is for plasma 6: https://www.pling.com/p/2117117/
Just add the widget through the plasma desktop and it will pick the right version.
I would suggest the arch wiki and reading about systemd timers and services.
yeah what ever kde uses you could set up as script to have it notify you
more in the arch wiki here
I tried to install it from the website https://store.kde.org/p/2117117/. But it did not work.
I downloaded the plasmoid file from the KDE store and then used the command kpackagetool6 --install to install it and it did not come up.Though I could see the files in $HOME/.local/share/kpackage/generic/com.dv.fokus/. I then uninstalled it with the command kpackagetool6 kpackagetool6 --install.
Funny is that I can still see the plasmaoid in the directory $HOME/.local/share/plasma/plasmoids/com.dv.fokus/.
How can I get it installed?
  • Right click on desktop → Enter Edit Mode
  • Click Add or Manage Widgets
  • Click Get New Widgets → Download New Plasma Widgets
  • Search for Fokus and install
How can I remove all the traces of Fokus that is already present on my system, prior to installing it from Edit mode? Like in $HOME/.local/share/plasma/plasmoids/com.dv.fokus/.
So finally got it to work. Thanks @Schlaefer. Next task is to get some pictures showing exercises to be done and run it via script using Fokus.
@thefrog I will be looking to use the notification daemon and a systemd-timer. But it will take some time.
