So, this recent nvidia-dkms 495.46 update has broken some of my software that I need for work.
I’m currently trying to downgrade it until there’s some fix.
Using the AUR’s downgrade script, I’m attempting to re-install nvidia-dkms 495.44 but there are some unresolvable dependencies stopping me.
warning: downgrading package nvidia-dkms (495.46-1 => 495.44-6)
resolving dependencies...
warning: cannot resolve "nvidia-utils=495.44", a dependency of "nvidia-dkms"
:: The following package cannot be upgraded due to unresolvable dependencies:
nvidia-dkms
:: Do you want to skip the above package for this upgrade? [y/N]
:: unable to satisfy dependency 'nvidia-utils=495.44' required by nvidia-dkms
I’m unsure how to go about resolving these and could use some help… Thanks a bunch for any help
I’m sure they are, even though NVIDIA had some reason to make such a small update.
I also wonder what the common factors are in those systems/installations finding an issue with the update, and whether it is the driver or something related to Python 3.10, a kernel module, or a module included in the initramfs.
The software not working for me is Steam, and my music production software, Bitwig.
Here’s what Steam via terminal gives me
[2022-01-03 05:50:23] Startup - updater built Dec 16 2021 22:39:04
Installing breakpad exception handler for appid(steam)/version(1639697812)
SteamUpdateUI: An X Error occurred
X Error of failed request: BadValue (integer parameter out of range for operation)
*****Edit: Also, to anyone who may find this thread on Google, lib32-nvidia-utils needed to be downgraded to match the version of nvidia-dkms and nvidia-utils.
