My wifi keeps getting disconnected after using for a while
After using wifi for a while my laptop keeps getting disconnected then reconnected and again disconnected. This doesn’t happen with other devices that are connected to the same wifi.
Which wifi card?
https://clbin.com/ZujXs
You could try some of these options in:
/etc/modprobe.d/iwlwifi.conf
options iwlwifi 11n_disable=1 bt_coex_active=0 power_save=0 auto_agg=0 swcrypto=1
One or more of these options may solve your issue.
I don’t have iwlwifi.conf. I just have default.conf wich is empty and a default.conf.save which only have options snd_hda_intel index=1.
You would have to create the file /etc/modprobe.d/iwlwifi.conf and add the options.
