My system wakes up by itself from standby
I configured the following settings in PM:
Whether manually via menu or after waiting 10 minutes, the system goes into standby.
I haven’t tracked exactly when it woke up again, but when I came back after some hours, the system was up.
Unfortunately, I don’t know where I can query the corresponding events, I just tried dmesg:
[frank@EOS ~]$ sudo dmesg -T | grep ACPI
[Mo,  5. Aug 2024, 14:01:03] ACPI: PM: Preparing to enter system sleep state S3
[Mo,  5. Aug 2024, 14:01:04] ACPI: PM: Saving platform NVS memory
[Mo,  5. Aug 2024, 14:01:04] ACPI: PM: Low-level resume complete
[Mo,  5. Aug 2024, 14:01:04] ACPI: PM: Restoring platform NVS memory
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[Mo,  5. Aug 2024, 14:01:04] ACPI: PM: Waking up from system sleep state S3
[Mo,  5. Aug 2024, 14:11:10] ACPI: PM: Preparing to enter system sleep state S3
<The above block is repeated every 10 minutes.>
[Mo,  5. Aug 2024, 15:01:43] ACPI: PM: Waking up from system sleep state S3
[Mo,  5. Aug 2024, 15:11:50] ACPI: PM: Preparing to enter system sleep state S3
[Mo,  5. Aug 2024, 15:11:50] ACPI: PM: Saving platform NVS memory
[Mo,  5. Aug 2024, 15:11:50] ACPI: PM: Low-level resume complete
[Mo,  5. Aug 2024, 15:11:50] ACPI: PM: Restoring platform NVS memory
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[Mo,  5. Aug 2024, 15:11:50] ACPI: PM: Waking up from system sleep state S3
And then without grep over the time frame at 15:01:
[Mo,  5. Aug 2024, 14:51:44] r8169 0000:0e:00.0 enp14s0: Link is Up - 1Gbps/Full - flow control rx/tx
[Mo,  5. Aug 2024, 15:01:42] r8169 0000:0e:00.0 enp14s0: Link is Down
[Mo,  5. Aug 2024, 15:01:42] PM: suspend entry (deep)
[Mo,  5. Aug 2024, 15:01:42] Filesystems sync: 0.007 seconds
[Mo,  5. Aug 2024, 15:01:42] Freezing user space processes
[Mo,  5. Aug 2024, 15:01:42] Freezing user space processes completed (elapsed 0.001 seconds)
[Mo,  5. Aug 2024, 15:01:42] OOM killer disabled.
[Mo,  5. Aug 2024, 15:01:42] Freezing remaining freezable tasks
[Mo,  5. Aug 2024, 15:01:42] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[Mo,  5. Aug 2024, 15:01:42] printk: Suspending console(s) (use no_console_suspend to debug)
[Mo,  5. Aug 2024, 15:01:42] queueing ieee80211 work while going to suspend
[Mo,  5. Aug 2024, 15:01:42] amdgpu 0000:03:00.0: amdgpu: MODE1 reset
[Mo,  5. Aug 2024, 15:01:42] amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
[Mo,  5. Aug 2024, 15:01:42] amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
[Mo,  5. Aug 2024, 15:01:43] ACPI: PM: Preparing to enter system sleep state S3
[Mo,  5. Aug 2024, 15:01:43] ACPI: PM: Saving platform NVS memory
[Mo,  5. Aug 2024, 15:01:43] Disabling non-boot CPUs ...
[Mo,  5. Aug 2024, 15:01:43] smpboot: CPU 1 is now offline
< shortened, CPU 2-7 >
[Mo,  5. Aug 2024, 15:01:43] smpboot: CPU 8 is now offline
[Mo,  5. Aug 2024, 15:01:43] Spectre V2 : Update user space SMT mitigation: STIBP off
[Mo,  5. Aug 2024, 15:01:43] smpboot: CPU 9 is now offline
< shortened, CPU 10-14 >
[Mo,  5. Aug 2024, 15:01:43] smpboot: CPU 15 is now offline
[Mo,  5. Aug 2024, 15:01:43] ACPI: PM: Low-level resume complete
[Mo,  5. Aug 2024, 15:01:43] ACPI: PM: Restoring platform NVS memory
[Mo,  5. Aug 2024, 15:01:43] AMD-Vi: Virtual APIC enabled
[Mo,  5. Aug 2024, 15:01:43] LVT offset 0 assigned for vector 0x400
[Mo,  5. Aug 2024, 15:01:43] Enabling non-boot CPUs ...
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 1 APIC 0x2
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU1 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 2 APIC 0x4
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU2 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 3 APIC 0x6
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU3 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 4 APIC 0x8
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU4 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 5 APIC 0xa
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU5 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 6 APIC 0xc
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU6 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 7 APIC 0xe
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU7 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 8 APIC 0x1
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[Mo,  5. Aug 2024, 15:01:43] CPU8 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 9 APIC 0x3
[Mo,  5. Aug 2024, 15:01:43] Spurious APIC interrupt (vector 0xFF) on CPU#9, should never happen.
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU9 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 10 APIC 0x5
[Mo,  5. Aug 2024, 15:01:43] Spurious APIC interrupt (vector 0xFF) on CPU#10, should never happen.
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU10 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 11 APIC 0x7
[Mo,  5. Aug 2024, 15:01:43] Spurious APIC interrupt (vector 0xFF) on CPU#11, should never happen.
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU11 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 12 APIC 0x9
[Mo,  5. Aug 2024, 15:01:43] Spurious APIC interrupt (vector 0xFF) on CPU#12, should never happen.
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU12 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 13 APIC 0xb
[Mo,  5. Aug 2024, 15:01:43] Spurious APIC interrupt (vector 0xFF) on CPU#13, should never happen.
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU13 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 14 APIC 0xd
[Mo,  5. Aug 2024, 15:01:43] Spurious APIC interrupt (vector 0xFF) on CPU#14, should never happen.
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU14 is up
[Mo,  5. Aug 2024, 15:01:43] smpboot: Booting Node 0 Processor 15 APIC 0xf
[Mo,  5. Aug 2024, 15:01:43] Spurious APIC interrupt (vector 0xFF) on CPU#15, should never happen.
[Mo,  5. Aug 2024, 15:01:43] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[Mo,  5. Aug 2024, 15:01:43] CPU15 is up
[Mo,  5. Aug 2024, 15:01:44] [drm] PCIE GART of 1024M enabled (table at 0x000000F41FC00000).
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: PSP is resuming...
[Mo,  5. Aug 2024, 15:01:44] nvme nvme0: D3 entry latency set to 10 seconds
[Mo,  5. Aug 2024, 15:01:44] xhci_hcd 0000:10:00.0: xHC error in resume, USBSTS 0x401, Reinit
[Mo,  5. Aug 2024, 15:01:44] usb usb1: root hub lost power or was reset
[Mo,  5. Aug 2024, 15:01:44] usb usb2: root hub lost power or was reset
[Mo,  5. Aug 2024, 15:01:44] [drm] PCIE GART of 512M enabled (table at 0x0000008000300000).
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
[Mo,  5. Aug 2024, 15:01:44] nvme nvme0: 16/0/0 default/read/poll queues
[Mo,  5. Aug 2024, 15:01:44] nvme nvme1: 8/0/0 default/read/poll queues
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: reserve 0xa00000 from 0xf41e000000 for PSP TMR
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: reserve 0xa700000 from 0x83e0000000 for PSP TMR
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: RAS: optional ras ta ucode is not available
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: RAP: optional rap ta ucode is not available
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: SMU is resuming...
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: SMU is resumed successfully!
[Mo,  5. Aug 2024, 15:01:44] [drm] DMUB hardware initialized: version=0x05001900
[Mo,  5. Aug 2024, 15:01:44] [drm] kiq ring mec 2 pipe 1 q 0
[Mo,  5. Aug 2024, 15:01:44] [drm] JPEG decode initialized successfully.
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:12:00.0: [drm] Cannot find any crtc or sizes
[Mo,  5. Aug 2024, 15:01:44] ata1: SATA link down (SStatus 0 SControl 300)
[Mo,  5. Aug 2024, 15:01:44] ata2: SATA link down (SStatus 0 SControl 300)
[Mo,  5. Aug 2024, 15:01:44] ata3: SATA link down (SStatus 0 SControl 300)
[Mo,  5. Aug 2024, 15:01:44] ata6: SATA link down (SStatus 0 SControl 300)
[Mo,  5. Aug 2024, 15:01:44] ata5: SATA link down (SStatus 0 SControl 300)
[Mo,  5. Aug 2024, 15:01:44] ata4: SATA link down (SStatus 0 SControl 300)
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000003d, smu fw if version = 0x00000040, smu fw program = 0, smu fw version = 0x00504f00 (80.79.0)
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[Mo,  5. Aug 2024, 15:01:44] usb 1-7: reset high-speed USB device number 5 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
[Mo,  5. Aug 2024, 15:01:44] [drm] DMUB hardware initialized: version=0x07002A00
[Mo,  5. Aug 2024, 15:01:44] [drm] kiq ring mec 3 pipe 1 q 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_1 uses VM inv eng 1 on hub 8
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 4 on hub 8
[Mo,  5. Aug 2024, 15:01:44] amdgpu 0000:03:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 14 on hub 0
[Mo,  5. Aug 2024, 15:01:44] [drm] ring gfx_32791.1.1 was added
[Mo,  5. Aug 2024, 15:01:44] [drm] ring compute_32791.2.2 was added
[Mo,  5. Aug 2024, 15:01:44] [drm] ring sdma_32791.3.3 was added
[Mo,  5. Aug 2024, 15:01:44] [drm] ring gfx_32791.1.1 ib test pass
[Mo,  5. Aug 2024, 15:01:44] [drm] ring compute_32791.2.2 ib test pass
[Mo,  5. Aug 2024, 15:01:44] [drm] ring sdma_32791.3.3 ib test pass
[Mo,  5. Aug 2024, 15:01:44] usb 1-12: reset high-speed USB device number 9 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:45] usb 1-5: reset high-speed USB device number 2 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:45] usb 1-8: reset low-speed USB device number 6 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:46] usb 1-10: reset full-speed USB device number 8 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:46] usb 1-6: reset high-speed USB device number 3 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:47] usb 1-9: reset full-speed USB device number 7 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:48] usb 2-5: reset SuperSpeed USB device number 2 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:48] usb 1-5.1: reset full-speed USB device number 4 using xhci_hcd
[Mo,  5. Aug 2024, 15:01:48] OOM killer enabled.
[Mo,  5. Aug 2024, 15:01:48] Restarting tasks ... done.
[Mo,  5. Aug 2024, 15:01:48] random: crng reseeded on system resumption
[Mo,  5. Aug 2024, 15:01:48] PM: suspend exit
[Mo,  5. Aug 2024, 15:01:48] Bluetooth: hci0: HW/SW Version: 0x008a008a, Build Time: 20240409163648
[Mo,  5. Aug 2024, 15:01:48] RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-e00:00: attached PHY driver (mii_bus:phy_addr=r8169-0-e00:00, irq=MAC)
[Mo,  5. Aug 2024, 15:01:48] pci_bus 0000:06: Allocating resources
[Mo,  5. Aug 2024, 15:01:48] Bluetooth: hci0: Device setup in 162102 usecs
[Mo,  5. Aug 2024, 15:01:48] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[Mo,  5. Aug 2024, 15:01:48] r8169 0000:0e:00.0 enp14s0: Link is Down
[Mo,  5. Aug 2024, 15:01:48] Bluetooth: hci0: AOSP extensions version v1.00
[Mo,  5. Aug 2024, 15:01:48] Bluetooth: hci0: AOSP quality report is supported
[Mo,  5. Aug 2024, 15:01:50] r8169 0000:0e:00.0 enp14s0: Link is Up - 1Gbps/Full - flow control rx/tx
[Mo,  5. Aug 2024, 15:11:49] r8169 0000:0e:00.0 enp14s0: Link is Down
Can you experts perhaps diagnose something here?
Or are there other ways/log files to detect the problem?
Thanks
