In the first try in advanced install mode i got exactly the same thing
Can you post your hardware and put code tags around what you post. Please use a full screen terminal to get the output.
inxi -Faz --no-host
Oh, in the basic installation it dont passed by the installing packages stage so it installed normally!
Hmm, ok
If you boot on the live Endeavour ISO you can use this and post the link.
inxi -Faz --no-host | eos-sendlog
Okā¦ But Iām not with the endeavour os iso im my usb now, and the arco is working fine here! And i need to quit nowā¦
Well you could post this from Arco also from a full screen terminal.
inxi -Faz --no-host
Ok, but i really need to leave nowā¦ I will post it when I get back ok?
Ok, im back! Hereās the results:
$ inxi -faz --no-host
Info: model: Intel Celeron N2808 bits: 64 type: MCP arch: Silvermont
family: 6 model-id: 0x37 (55) stepping: 8 microcode: 0x809
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 526 high: 547 min/max: 500/2249 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 505 2: 547
bogomips: 6335
Flags: 3dnowprefetch acpi aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ida lahf_lm lm mca mce mmx monitor movbe msr
mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni popcnt
pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2 sse4_1 sse4_2
ssse3 syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology xtpr
Vulnerabilities:
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spec_store_bypass status: Not affected
Type: spectre_v1
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Wheres the rest of it?
Edit: You could copy and paste the whole page to the bottom if you run it again and edit your post to show all of it.
Rest of it? Thereās more? Okā¦
Ok, like this?
Well itās not the whole output. You need to copy the whole thing right to the bottom.
Better copy paste from the posterās post. Thereās a typo.
inxi -Faz
āno-host serves on an installed system. On the installer the host is the sameā¦
I didnāt even notice the error.
--no-host
is not needed at all when there is -z
-z, --filter Adds security filters for IP/MAC addresses, serial numbers,
location (-w), user home directory name, host name.
Ok, so it it should be like this? Now i got what i was doing wrong the āfā should be in caps!
$ inxi -Faz
Kernel: 5.16.1-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0 parameters: ro
root=UUID=1d4b1271-025c-4326-80af-42dfac8e2655
initrd=boot\initramfs-linux.img
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Distro: ArcoLinux base: Arch Linux
Type: Laptop System: Positivo Informatica SA product: H14BT58 v: 1.07.U
Mobo: Positivo Informatica SA model: H14BT58 serial: <superuser required>
UEFI: American Megatrends v: 1.07.U date: 05/15/2015
Battery:
ID-1: BAT0 charge: 7.2 Wh (100.0%) condition: 7.2/15.8 Wh (45.5%)
volts: 8.1 min: 7.2 model: standard type: Li-ion serial: <filter>
status: Full
Speed (MHz): avg: 564 high: 629 min/max: 500/2249 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 629 2: 500
bogomips: 6335
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: mds
Type: spectre_v1
Type: spectre_v2
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Holco Enterprise Co /Shuttle driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0f31 class-ID: 0300
Device-2: Chicony USB 2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-3.3:5 chip-ID: 04f2:b539 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting unloaded: fbdev,vesa alternate: intel display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112
size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 21.3.4
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Holco Enterprise Co /Shuttle driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:0f04 class-ID: 0403
Sound Server-1: ALSA v: k5.16.1-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter vendor: AzureWave
driver: rtl8188ee v: kernel modules: wl port: e000 bus-ID: 01:00.0
chip-ID: 10ec:8179 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
vendor: Holco Enterprise Co /Shuttle driver: r8169 v: kernel modules: r8168
port: d000 bus-ID: 02:00.2 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f2 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 465.76 GiB used: 14.4 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2A scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 14.39 GiB (29.4%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 11.5 MiB (12.0%) fs: vfat dev: /dev/sda2 maj-min: 8:2
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 164 Uptime: 11m wakeups: 1 Memory: 1.82 GiB
used: 1.14 GiB (62.6%) Init: systemd v: 250 target: graphical.target
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1226 pacman: 1219 lib: 247
flatpak: 7 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
What exactly have you changed after my advice??
If you canāt see the problem here, we have a serious communication regressionā¦
Just copy the command from my post and paste to terminal.
Unless you are trollingā¦ I like trolling, too. We can do this forever
Edit: And there you areā¦
Sorry, Iām not good with English and iām kinda slow too so i didnāt noticed what you were talking about. fixed now!
Your system hardware is not really capable of running KDE well. If you could have it functional, your best choices are some of the less demanding (light) DE/WMs, like Openbox, LXQt, BSPWM etc.
With as low as 2 GB of RAM you canāt have much of the modern DEs.
I suggest you try EnOS bspwm or i3, after checking out some video presentations on the web, so you know what to expect.
Arcolinux has some of them available as well.
