ng0177
1
On my laptop:
- ALSA
- pipewire
- wireplumber
seem to work fine but since a recent either kernel or software update - after hot plug of the Jabra Headset, I am only allowed to choose:
- Laptop microphone (although disabled in bios) and Jabra speaker
- or vice versa.
If the headset is connected from boot onwards, then no problem.
Can you use pavucontrol
to configure the devices?
Yes, works but mirrors what I see in gnome-settings
ng0177
4
Any advice where create a bug report?
ng0177
5
pipewire-media-session
installed to replace wireplumber
: problem solved!
system
Closed
6
