I cant see the Internal or External memory on my mobile in the file manager:
cable and everything is good.
done file transfer with the same cable and on the same mobile device this morning on windows.
I tried that too
Was that on the same PC?
check journal while plug-in device and try to open it in filebrowser:
journalctl -f
and check output for hints (always the first thing I would do)
This has suddenly happened to me too. Works on windows and a kubuntu installation.
Problem is libmtp which was upgraded a couple of days ago to 1.1.19-1. Downgrade to previous version works. libmtp 1.1.18-1.
This is also on the arch forum.
https://archlinux.org/packages/extra/x86_64/libmtp/
https://bbs.archlinux.org/viewtopic.php?id=270027
https://bbs.archlinux.org/viewtopic.php?id=269967
to complete…
we have downgrade preinstalled sudo downgrade libmtp
But keep an eye on updates so that you do not forget to have it downgraded… best is not top add it to ignore list.
Now I have tested with three devices redmi note 4
Relme 5i and a old Samsung (don’t know the model)
Mtp is working with later two devices ,but not with redmi note 4
But on windows and manjaro all devices are detected.
Isn’t this why we love Arch/Arch-based systems!
Did you
and pick version
Sometimes I feel like doing workarounds
i.e. Run FTP server off Android phone
