Each time I start mpd the volume has reset to 100%, which is far too loud for me. From what I understand defining a statefile in mpd’s config is supposed to keep this from happening, however, it continues to do so even with a statefile which contains sw_volume: 30
I have tried setting the volume with mpc and ncmpcpp, neither persist.
I have tried starting mpd as a service, and via the terminal.
I have removed the configuration I store in home for both mpd and ncmpcpp, doing so made no difference.
Last but not least I have also tried both PulseAudio and PipeWire as outputs.
I have rw access to, and own the statefile, and since it restores the queue and mode it seems to read the file, but not the volume state.
mpdstate
sw_volume: 30
audio_device_state:1:pulse audio
audio_device_state:1:Visualizer
state: pause
current: 0
time: 38.232000
random: 0
repeat: 0
single: 0
consume: 0
crossfade: 0
mixrampdb: 0.000000
mixrampdelay: -1.000000
Current mpd config
bind_to_address "127.0.0.1"
port "6600"
auto_update "yes"
restore_paused "yes"
music_directory "/mnt/D1/MEDIA/MUSIC/MPD/MUSIC/"
playlist_directory "~/.mpd/playlists"
db_file "~/.mpd/mpd.db"
log_file "~/.mpd/mpd.log"
pid_file "~/.mpd/mpd.pid"
state_file "~/.mpd/mpdstate"
audio_output {
type "pulse"
name "pulse audio"
audio_output {
type "fifo"
name "Visualizer"
path "/tmp/mpd.fifo"
format "44100:16:2"
