good day all
i have been playing around with my mpd conf file but i’m not coming right. what i’m trying to do is get mpd running and point it to my mp3’s that i ripped from my cd collection that is on my smb/nfs share that is on another system. so the whole setup is only for lan
music_directory “nfs://attic/music/”
playlist_directory “/home/angelus/.config/mpd/playlists”
db_file “/home/angelus/.config/mpd/database”
log_file “/home/angelus/.config/mpd/syslog”
pid_file “/home/angelus/.config/mpd/pid”
state_file “/home/angelus/.config/mpd/state”
sticker_file “/home/angelus/.config/mpd/sticker.sql”
user “angelus”
bind_to_address “any”
bind_to_address “0.0.0.0”
port “6600”
log_level “verbose”
database {
plugin “simple”
path “/home/angelus/.config/mpd/db”
cache_directory “/home/angelus/.config/mpd/cache”
database {
plugin “proxy”
host "router IP ?? "
port “6600”
input {
plugin “curl”
audio_output {
type “alsa”
name “My ALSA Device”
server “127.0.0.1”
if i run mcg update i get a error of
(mcg:5534): GLib-GIO-CRITICAL **: 01:42:04.378: This application can not open files.
a systemctl status mpd gives me
mpd.service - Music Player Daemon
Loaded: loaded (/usr/lib/systemd/system/mpd.service; disabled; vendor preset: disabled)
Active: active (running) since Mon 2021-05-03 02:12:56 SAST; 1min 48s ago
Docs: man:mpd(1)
man:mpd.conf(5)
Main PID: 6486 (mpd)
Tasks: 3 (limit: 19122)
Memory: 9.0M
CPU: 86ms
CGroup: /system.slice/mpd.service
└─6486 /usr/bin/mpd --no-daemonMay 03 02:12:56 Angelus systemd[1]: Starting Music Player Daemon…
May 03 02:12:56 Angelus mpd[6486]: exception: bind to ‘0.0.0.0:6600’ failed (continuing anyway, because binding to ‘[::]:6600’ succeeded): Failed to bind socket: Address already in use
May 03 02:12:56 Angelus mpd[6486]: exception: Decoder plugin ‘wildmidi’ is unavailable: configuration file does not exist: /etc/timidity/timidity.cfg
May 03 02:12:56 Angelus mpd[6486]: config: Found database setting without music_directory - disabling database
May 03 02:12:56 Angelus mpd[6486]: output: No ‘audio_output’ defined in config file
May 03 02:12:56 Angelus mpd[6486]: output: Successfully detected a alsa audio device
May 03 02:12:56 Angelus systemd[1]: Started Music Player Daemon.
May 03 02:12:57 Angelus mpd[6486]: avahi: Service ‘Music Player @ Angelus’ successfully established
