I have installed mousepad on xfce and installed
hunspell-en_au.
https://docs.xfce.org/apps/mousepad/start#required_packages
said I needed gspell and libxfce4ui which I installed.
However, spell check not working?
hunspell-en_au.
Hello,
I had the same problem before under Suse and found the solution.
Here endeavouros but the package names are very similar.
Needed is hunspell
, enchant-pure
and now very important enchant-hspell
INFO: If enchant is already installed a package swap to enchant-pure is done.
For my german language area I had to install hunspell-de
With this it should work. For me it does.
Thanks pebcak
that is always the first thing I check.
Hi HPF-84E,
you were right in around about way. I check the repos first for the packages you suggested. There was “enchant” and php-enchant, so I installed “enchant” and it worked! Thanks.
