I am aware that this is more of a plasma problem than an EOS problem, but it could still be that someone here has the same experience and already has a solution.
Since some time it happens more and more often that after a restart of EOS (KDE) both the background image and the settings for the shortcuts were reset. Also all widgets are gone. It probably does not happen depending on a previous update, rather sporadically. But it sucks!!!
The symbols will all be placed on the top left again. Theme Breeze Standard
By settings are meant: arrangement of symbol shortcuts, disabling the preview for Sybol shortcuts and files, background image. All this + added widgets will be reset after a restart.
You right, its not the good link and i don’t find the correct one But yeah happen to me too. Now i have a doubt, pretty sure its fixed in 5.26 (maybe already on the beta ?).
For the background, you can run a script at start-up like me:
This is very strange, nothing like this happens to me. The only thing atypical is I usually only mess with my settings once…and then they stay forever. I run Wayland (if that affects anything at all).
