Hello,
I’m running Gnome and I can’t get my monitors to sleep after a specific period of time (in Gnome settings power section I have it set to 15 mins).
The monitors just start showing a black background instead and moving my mouse shows me login screen.
Doing sleep 1; xset dpms force off
works just fine so I’m confused?
Usually this happened after kernel update and I needed to reboot but this time it broke a few kernel updates ago and nothing seems to fix it.
I’m running RTX 3070 with Nvidia drivers.
This is the normal behavior. It’s not the login screen, it’s the session lock screen, which looks the same.
What was the previous behavior, or what you expect exactly?
But the monitors do not enter sleep mode, I can see the backlight is still on and the monitor LED is ON.
What should happen is monitors should enter sleep or power saving mode - backlight should turn off completely and LEDs should be blinking indicating monitor is in power saving mode.
Ok I kinda solved it…
so I did xset dpms 0 0 60
… now it works and turns off my monitor every minute… except I can no longer set it to xset dpms 0 0 900
it just keeps turning off every minute.
❯ xset -q
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000002
XKB indicators:
00: Caps Lock: off 01: Num Lock: on 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 500 repeat rate: 33
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 50 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 2/1 threshold: 4
Screen Saver:
prefer blanking: yes allow exposures: yes
timeout: 0 cycle: 0
Colors:
default colormap: 0x20 BlackPixel: 0x0 WhitePixel: 0xffffff
Font Path:
built-ins
DPMS (Energy Star):
Standby: 0 Suspend: 0 Off: 900
DPMS is Enabled
Monitor is On
Something is seriously wrong here…
Was this the previous behavior?
Which packages were added or updated before this started ?
Is power-profiles-daemon
installed and if so, when was it initially added?
Read more, since it’s a complicated issue, with many factors (HW and SW).
At least:
https://wiki.archlinux.org/title/CPU_frequency_scaling#power-profiles-daemon
Also check:
https://wiki.archlinux.org/title/Display_Power_Management_Signaling
PPD issues
Post the results of your troubleshooting investigation, as proposed from the above.
Ok now I see what happened, the software didn’t change, however my hardware did - I had to buy a new monitor and it behaves differently.
So what is happening is my monitors go to power saving as usual, but the new monitor stops being detected by the system, so after a few seconds in power saving mode window manager readjusts for only 2 displays which causes all monitors to wake up, this again triggers OS to readjust for 3 screens but now the displays are no longer sent to power saving mode, gnome simply starts showing black screen after a while.
I have no idea how to solve this? All monitors are connected over Display Port.
There is nothing related to power saving settings in monitor OSD except what power button does but it is not helpful. The monitor is MSI mag274qrf-qd but I doubt it depends on the monitor, must be something related to Display Port itself?
I suppose you have not read the monitor’s User Manual, or have you? What does it say on this matter?
There is nothing useful in the user manual about the power saving mode, only a special HDMI mode for consoles and such but I can’t use HDMI because of 165Hz
Post a link to the manual.
Also provide more info (garuda-inxi output). Edit: Mixed forum
You mean this?
❯ inxi -faMzSG
Kernel: 5.16.15-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/vmlinuz-linux
root=UUID=c13714ba-4389-4b48-b547-8b95e691c819 rw rootflags=subvol=@
acpi_enforce_resources=lax quiet splash
cryptdevice=UUID=bd1174a3-4cab-4a9a-92f1-2aa046e0d621:luks-bd1174a3-4cab-4a9a-92f1-2aa046e0d621
root=/dev/mapper/luks-bd1174a3-4cab-4a9a-92f1-2aa046e0d621 loglevel=3
nowatchdog nvme_load=YES
Desktop: GNOME 41.4 tk: GTK 3.24.33 wm: gnome-shell dm: GDM 41.3
Distro: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2477 high: 4537 min/max: 2200/5160 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2983 2: 2591
3: 2654 4: 2649 5: 2529 6: 2947 7: 2027 8: 2014 9: 2037 10: 2024 11: 2046
12: 2183 13: 4537 14: 2647 15: 2657 16: 2663 17: 2661 18: 3351 19: 2039
20: 2050 21: 2050 22: 2072 23: 2027 24: 2027 bogomips: 177683
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt
nrip_save nx ospke osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni
popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep
sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 08:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: Creative Live! Cam Sync 1080p V2 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.3:9 chip-ID: 041e:40a0
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 7680x1440 s-dpi: 96 s-size: 2032x381mm (80.0x15.0")
s-diag: 2067mm (81.4")
Monitor-1: DP-0 pos: right res: 2560x1440 hz: 120 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-2 pos: primary,left res: 2560x1440 hz: 120 dpi: 109
Monitor-3: DP-4 pos: primary,center res: 2560x1440 dpi: 109
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
More:
inxi -Faz
xrandr
❯ inxi -Faz
Distro: Arch Linux
date: 08/10/2021
Battery:
Device-1: hidpp_battery_0 model: Logitech G604 Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Speed (MHz): avg: 2377 high: 3259 min/max: 2200/5160 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2207 2: 2984
3: 2660 4: 2669 5: 2655 6: 3213 7: 2037 8: 2032 9: 2029 10: 2036 11: 2029
12: 2075 13: 3259 14: 2682 15: 2657 16: 2649 17: 2143 18: 2808 19: 2041
20: 2029 21: 2039 22: 2020 23: 2062 24: 2046 bogomips: 177683
Vulnerabilities:
Type: spectre_v1
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 08:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Texas Instruments SMSL AD18 AMP type: USB driver: snd-usb-audio
bus-ID: 1-1.2:6 chip-ID: 0451:0003 class-ID: 0102
Device-4: Creative Live! Cam Sync 1080p V2 type: USB
Device-5: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.4:10
chip-ID: 0c76:161e class-ID: 0300
Sound Server-1: ALSA v: k5.16.15-arch1-1 running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.48 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-e2c8e129f5a3 state: down mac: <filter>
IF-ID-2: br-e5efaba6d3d8 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: vethd2d67e7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethe91f2b0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Bluetooth:
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:7 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 3.68 TiB used: 183.98 GiB (4.9%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: A-Data model: SX8200PNP
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 42B4S9NA temp: 35.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z44106
temp: 37.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 183.71 GiB (9.6%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-bd1174a3-4cab-4a9a-92f1-2aa046e0d621
ID-2: /boot raw-size: 1024 MiB size: 975.9 MiB (95.30%)
used: 278.3 MiB (28.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
ID-3: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 1.3 MiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-4: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 183.71 GiB (9.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
System Temperatures: cpu: 44.5 C mobo: 34.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 320 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
fan-7: 368
Processes: 590 Uptime: 12h 1m wakeups: 20 Memory: 31.32 GiB
used: 7.43 GiB (23.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1290 lib: 406 Shell: Zsh v: 5.8.1
running-in: gjs inxi: 3.3.13
❯ xrandr
Screen 0: minimum 8 x 8, current 7680 x 1440, maximum 32767 x 32767
DP-0 connected 2560x1440+5120+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 120.00*+ 59.95
1920x1080 119.88 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-4 connected primary 2560x1440+2560+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.94 + 164.83* 120.00
3840x2160 59.94 29.97
1920x1080 164.89 119.88 100.00 60.00 59.94 50.00
1680x1050 59.95
1440x900 59.89
1280x720 119.88 100.00 59.94 50.00
720x576 50.00
720x480 59.94
DP-5 disconnected (normal left inverted right x axis y axis)
Check for PM settings for monitors in Nvidia Settings.
Other than that, search at the previous post links or more on the web for this.
It’s a special case with 3 identical monitors, all DP and only one is disabled.
Are they all the same model or company?
Have you tried switching ports on GPU?
I think I fixed it, I disabled input auto scanning in monitor OSD and locked it to display port, seems it is no longer “lost” to the system when going into power saving mode!
I will report back if it happens again but looks promising, thanks for the help
