Since I did last update (today) every 20 seconds my monitor turns black for 5 seconds and then turns back. Impossible to work, very annoying! Any suggestions?
Post the output of inxi -Faz
so people can see what your system is, and identify which packages you updated by looking in /var/log/pacman.log
Hello, thanks for your answer. This is the demanded output:
Kernel: 5.15.7-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=d9817b3c-a8fd-4f82-9b08-41de8ea4f911 rw quiet loglevel=3
nowatchdog
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: ASUSTeK model: P8Z77-M PRO v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 1504
date: 08/03/2012
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 6943.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 6948.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6950.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6953.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6954.
serial: <filter> charge: 100% (should be ignored) rechargeable: yes status:
Info: model: Intel Core i3-2100 bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1627 high: 1694 min/max: 1600/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1605 2: 1605 3: 1605
4: 1694 bogomips: 24882
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX unsupported
Type: l1tf mitigation: PTE Inversion
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
IBRS_FW, STIBP: conditional, RSB filling
Device-1: AMD RV620 LE [Radeon HD 3450] vendor: ASUSTeK driver: radeon
v: kernel bus-ID: 01:00.0 chip-ID: 1002:95c5 class-ID: 0300
Display: wayland server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: radeon note: n/a (using device driver) - try sudo/root
display-ID: 0 resolution: <missing: xdpyinfo>
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: AMD RV620 HDMI Audio [Radeon HD 3450/3470/3550/3570]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa28 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.41 running: no
vendor: ASUSTeK P8 series driver: r8168 v: 8.049.02-NAPI modules: r8169
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 704.24 GiB used: 139.85 GiB (19.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: ST9500424AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: HDD
rpm: 7200 serial: <filter> rev: 0214 scheme: GPT
ID-1: / raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
used: 16.18 GiB (6.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 63.0 C
Fan Speeds (RPM): N/A
Processes: 213 Uptime: 5m wakeups: 2 Memory: 7.72 GiB
used: 1.26 GiB (16.3%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 879 lib: 248 Shell: Bash v: 5.1.12
running-in: gnome-terminal inxi: 3.3.10
MOD Edit: Fixed Formatting
Have you tried switching to the lts kernel and/or X11?
Is it exactly everytime 20 secounds or is it sarcasm?
Tried to disable screensaver and disable the energy options under settings?
Also what extensions are you using with Gnome?
No, it’s not sarcasm. The strange thing is the following: the longer the computer runs, the problem get’s worser. After working 30 minutes it happens maybe every two minutes, later it literally happens all 10 seconds and I must jump to my windows installation. Of course it’s impossible to do anymore work.
I would definitely try the LTS kernel. It is an easy thing to test out.
sudo pacman -S linux-lts linux-lts-headers
Then reboot and choose the LTS option from the boot menu
As well, you should check your temperatures, since high temperatures can cause driver to crash which converts in experience you have.
Are you overclocking, gaming?
Also did you try login in the xorg instead Wayland session, maybe worth a shot too, in addition to running lts kernel.
Hello dalto,
did this, but no changes. In the boot menu I did not have had the option to choose, but I think the LTS Kernel was loaded anyway, because the internet connection has gone.
No, no overclocking, no gaming. Yes, I tried to login with xorg, nothing changed. Also did change to XFCE instead Gnome, did change nothing. Also already tried all display managers, nothing better.
Hello razor,
this is an interesting idea. Will check temperature. But if this is indeed the problem, it seems related to Linux.
If so, how can this be resolved? On Windows never had something similar.
If that is the problem, you can look into TLP.
This doesn’t tell us much, except that it may be related to your Linux install or proprietary/unsupported hardware driver.
Try lts kernel as mentioned twice above before trying anything else, sometimes it’s a driver update in the kernel.
As there is a parallel thread on the very same topic let’s close this one here. @moderators
That topic is a bit different than this one and it doesn’t seem like the problem has been solved so I think it is OK to leave both open.
Thanks to all here and also I wish you all a Happy New Year!
The solution finally was so simple: I changed from HDMI to Display Port and everything is fine! No more problems. Maybe something was wrong with the cable. And I switched back from Manjoro to Endeavouros.
