Missing wallpaper - possible graphics issue?
Right, I’m having issues pinning down exactly what is wrong here other then it seems graphics related, so bear with me:
Recent install as a dualboot with Win11 (issue is specifically on the EndeavourOS side, just for context) on a Aegis R 14NUE7-680US w/ Core™ i7-14700F RTX 4070 SUPER computer, with two monitors. The graphics have been… temperamental.
The clearest current manifestation of this is the wallpaper on my main monitor has gone missing, and is now just a black screen no matter what I do (trying to change the wallpaper, resetting, etc.) - this isn’t the case with the second monitor, which is not having this issue. The main monitor otherwise seems to be functioning.
I’ve also been getting some other graphical issues - XIVLauncher-RB causes both itself and the entire display to reset repeatedly until it fully loads, and I have a Reshade install that crashes when loading effects seemingly due to something with the graphics according to the log(but it functions fine if I get it to load, it’s just loading new effects), as examples.
I have Nvidia drivers installed visa nvidia-inst, they are up to date and correct to my knowledge (550.90.07), and otherwise seem to function fine - Steam and games through Steam generally work fine, etc.
KDE Desktop, X11 (Wayland gave me other issues).
I did xprop both of the monitors, hidden for space:
Main Monitor / the one with the issue
AT_SPI_BUS(STRING) = “unix:path=/run/user/1000/at-spi/bus_0”
GDK_VISUALS(INTEGER) = 43, 130
_NET_WORKAREA(CARDINAL) = 0, 0, 3840, 1035
_KDE_SLIDE(_KDE_SLIDE) = 0x0
_KDE_KWIN_KSCREEN_SUPPORT(_KDE_KWIN_KSCREEN_SUPPORT) = 0x0
_KDE_WINDOW_HIGHLIGHT(_KDE_WINDOW_HIGHLIGHT) = 0x0
_KDE_NET_WM_BACKGROUND_CONTRAST_REGION(_KDE_NET_WM_BACKGROUND_CONTRAST_REGION) = 0x0
_KDE_NET_WM_BLUR_BEHIND_REGION(_KDE_NET_WM_BLUR_BEHIND_REGION) = 0x0
_NET_CLIENT_LIST_STACKING(WINDOW): window id # 0x600017, 0x600022, 0x4600007, 0x6400005, 0x5000004, 0x5000005, 0x3c00014, 0x600092, 0x600059
_NET_CLIENT_LIST(WINDOW): window id # 0x600017, 0x600022, 0x4600007, 0x600059, 0x600092, 0x5000004, 0x5000005, 0x6400005, 0x3c00014
_NET_DESKTOP_GEOMETRY(CARDINAL) = 3840, 1080
_NET_ACTIVE_WINDOW(WINDOW): window id # 0x3c00014
_NET_DESKTOP_NAMES(UTF8_STRING) = “Desktop 1”
_NET_CURRENT_DESKTOP(CARDINAL) = 0
_NET_DESKTOP_LAYOUT(CARDINAL) = 0, 1, 1, 0
_NET_DESKTOP_VIEWPORT(CARDINAL) = 0, 0
_NET_NUMBER_OF_DESKTOPS(CARDINAL) = 1
_NET_SUPPORTING_WM_CHECK(WINDOW): window id # 0x120000f
_NET_SUPPORTED(ATOM) = _NET_SUPPORTED, _NET_SUPPORTING_WM_CHECK, _NET_CLIENT_LIST, _NET_CLIENT_LIST_STACKING, _NET_NUMBER_OF_DESKTOPS, _NET_DESKTOP_GEOMETRY, _NET_CURRENT_DESKTOP, _NET_DESKTOP_NAMES, _NET_ACTIVE_WINDOW, _NET_WORKAREA, _NET_DESKTOP_LAYOUT, _NET_CLOSE_WINDOW, _NET_RESTACK_WINDOW, _NET_SHOWING_DESKTOP, _NET_WM_MOVERESIZE, _NET_MOVERESIZE_WINDOW, _NET_WM_NAME, _NET_WM_VISIBLE_NAME, _NET_WM_DESKTOP, _NET_WM_WINDOW_TYPE, _NET_WM_WINDOW_TYPE_NORMAL, _NET_WM_WINDOW_TYPE_DESKTOP, _NET_WM_WINDOW_TYPE_DOCK, _NET_WM_WINDOW_TYPE_TOOLBAR, _NET_WM_WINDOW_TYPE_MENU, _NET_WM_WINDOW_TYPE_DIALOG, _NET_WM_WINDOW_TYPE_UTILITY, _NET_WM_WINDOW_TYPE_SPLASH, _KDE_NET_WM_WINDOW_TYPE_OVERRIDE, _NET_WM_STATE, _NET_WM_STATE_MODAL, _NET_WM_STATE_MAXIMIZED_VERT, _NET_WM_STATE_MAXIMIZED_HORZ, _NET_WM_STATE_SHADED, _NET_WM_STATE_SKIP_TASKBAR, _NET_WM_STATE_SKIP_PAGER, _KDE_NET_WM_STATE_SKIP_SWITCHER, _NET_WM_STATE_HIDDEN, _NET_WM_STATE_FULLSCREEN, _NET_WM_STATE_ABOVE, _NET_WM_STATE_STAYS_ON_TOP, _NET_WM_STATE_BELOW, _NET_WM_STATE_DEMANDS_ATTENTION, _NET_WM_STATE_FOCUSED, _NET_WM_STRUT, _NET_WM_STRUT_PARTIAL, _NET_WM_ICON_GEOMETRY, _NET_WM_ICON, _NET_WM_PID, _NET_WM_PING, _NET_WM_USER_TIME, _NET_STARTUP_ID, _NET_WM_WINDOW_OPACITY, _NET_WM_FULLSCREEN_MONITORS, _NET_WM_ALLOWED_ACTIONS, _NET_WM_ACTION_MOVE, _NET_WM_ACTION_RESIZE, _NET_WM_ACTION_MINIMIZE, _NET_WM_ACTION_SHADE, _NET_WM_ACTION_MAXIMIZE_VERT, _NET_WM_ACTION_MAXIMIZE_HORZ, _NET_WM_ACTION_FULLSCREEN, _NET_WM_ACTION_CHANGE_DESKTOP, _NET_WM_ACTION_CLOSE, _NET_FRAME_EXTENTS, _KDE_NET_WM_FRAME_STRUT, _NET_WM_FULL_PLACEMENT, _KDE_NET_WM_ACTIVITIES, _KDE_NET_WM_SHADOW, _NET_WM_OPAQUE_REGION, _GTK_FRAME_EXTENTS, _GTK_SHOW_WINDOW_MENU
_QT_GET_TIMESTAMP(INTEGER) =
QT_SETTINGS_TIMESTAMP:0(QT_SETTINGS_TIMESTAMP:0) = 0x0, 0x0, 0x0, 0x0, 0x0, 0x25, 0x8b, 0x46, 0x4, 0xf, 0x70, 0xb9, 0x0
RESOURCE_MANAGER(STRING) = “Xcursor.size:\t24\nXcursor.theme:\tSweet-cursors\nXft.antialias:\t1\nXft.dpi:\t96\nXft.hinting:\t1\nXft.hintstyle:\thintslight\nXft.rgba:\trgb\n”
_XKB_RULES_NAMES(STRING) = “evdev”, “pc104”, “ca,ca”, “eng,sun_type6”, “grp:lctrl_lwin_rctrl_menu”
XFree86_has_VT(INTEGER) = 1
XFree86_VT(INTEGER) = 2
Xorg_Seat(STRING) = “seat0”
Secondary Monitor / one without issues
_NET_WM_ALLOWED_ACTIONS(ATOM) = _NET_WM_ACTION_CHANGE_DESKTOP
_NET_WM_DESKTOP(CARDINAL) = 4294967295
WM_STATE(WM_STATE):
window state: Normal
icon window: 0x0
_NET_WM_USER_TIME(CARDINAL) = 15603
_KDE_NET_WM_USER_CREATION_TIME(CARDINAL) = 15621
_NET_WM_STATE(ATOM) = _NET_WM_STATE_BELOW
XdndAware(ATOM) = BITMAP
WM_NAME(STRING) = "Desktop @ QRect(0,0 1920x1080) "
_NET_WM_NAME(UTF8_STRING) = "Desktop @ QRect(0,0 1920x1080) "
_MOTIF_WM_HINTS(_MOTIF_WM_HINTS) = 0x2, 0x1, 0x0, 0x0, 0x0
_NET_WM_WINDOW_TYPE(ATOM) = _NET_WM_WINDOW_TYPE_DESKTOP
_XEMBED_INFO(_XEMBED_INFO) = 0x0, 0x1
WM_CLIENT_LEADER(WINDOW): window id # 0x600019
WM_HINTS(WM_HINTS):
Client accepts input or input focus: True
window id # of group leader: 0x600019
WM_CLIENT_MACHINE(STRING) = “ADAMO”
_NET_WM_PID(CARDINAL) = 1113
_NET_WM_SYNC_REQUEST_COUNTER(CARDINAL) = 6291491
_GTK_APPLICATION_ID(UTF8_STRING) = “org.kde.plasmashell”
_KDE_NET_WM_DESKTOP_FILE(UTF8_STRING) = “org.kde.plasmashell”
WM_CLASS(STRING) = “plasmashell”, “plasmashell”
WM_PROTOCOLS(ATOM): protocols WM_DELETE_WINDOW, WM_TAKE_FOCUS, _NET_WM_PING, _NET_WM_SYNC_REQUEST
WM_NORMAL_HINTS(WM_SIZE_HINTS):
user specified location: 0, 0
user specified size: 1920 by 1080
window gravity: Static
Thanks in advance!
