Missing EndeavourOS boot option after not using pc for month
I went on a trip for a month and came back to find the endeavourOS boot option missing from my pc,
i had a dual boot of windows and endeavourOS, when i started it after coming back it seems bios was reset and after it self restarted 5 times it found windows boot option but failed to find endeavourOS boot option.. pls help
I see….i see….no specs or anything in your post.
Did you chroot into the system ?
Did you post any logs ?
Did you update windows before you left ?
We need more info, we can’t help you and guess around.
The first thing I would do is to look at the fact why de Bios did the reset(s) , maybe a dead cmos battery , or a corrupt Bios things like that.
only used endeavourOS, didnt update windows for more than a year
specs:
Pentium g4400
rx 550
H110MHv3 mobo
8 gigs of ram
ill chroot into the system now and try to send logs
This wiki can help you to repair Grub.
this fixed it thanks :slight_smile:
