Minecraft has a high ping
is iw dev wlan0 station dump a command?
Sorry that was vague (edited now). Yes it is.
Perhaps do a bit more surfing and activity, then run that again. Not a lot of data has gone through that yet.
this good?
	inactive time:	2207 ms
	rx bytes:	2653492
	rx packets:	3182
	tx bytes:	153430
	tx packets:	385
	tx retries:	0
	tx failed:	0
	beacon loss:	123
	beacon rx:	599
	rx drop misc:	6
	signal:  	-31 [-78, -31] dBm
	signal avg:	-37 [-79, -37] dBm
	beacon signal avg:	-35 dBm
	tx bitrate:	129.0 MBit/s HE-MCS 10 HE-NSS 1 HE-GI 0 HE-DCM 0
	tx duration:	0 us
	rx bitrate:	114.7 MBit/s HE-MCS 9 HE-NSS 1 HE-GI 0 HE-DCM 0
	rx duration:	0 us
	authorized:	yes
	authenticated:	yes
	associated:	yes
	preamble:	long
	WMM/WME:	yes
	MFP:		no
	TDLS peer:	no
	DTIM period:	1
	beacon interval:100
	short slot time:yes
	connected time:	66 seconds
	associated at [boottime]:	4812.122s
	associated at:	1736413923559 ms
	current time:	1736413988923 ms
I would venture to say no…just based on mine. Your wireless is basically unstable (imo).
Station 94:83:c4:0e:25:35 (on wlan0)
        inactive time:  1 ms
        rx bytes:       10524664760
        rx packets:     10473291
        tx bytes:       7362411209
        tx packets:     8972317
        tx retries:     689451
        tx failed:      0
        beacon loss:    0
        rx drop misc:   0
        signal:         -51 [-54, -54] dBm
        signal avg:     -50 [-53, -53] dBm
        tx bitrate:     650.0 MBit/s VHT-MCS 7 80MHz short GI VHT-NSS 2
        tx duration:    159322984933 us
        rx bitrate:     866.7 MBit/s VHT-MCS 9 80MHz short GI VHT-NSS 2
        rx duration:    133498926796 us
        last ack signal:-51 dBm
        avg ack signal: -49 dBm
        airtime weight: 256
        authorized:     yes
        authenticated:  yes
        associated:     yes
        preamble:       long
        WMM/WME:        yes
        MFP:            no
        TDLS peer:      no
        DTIM period:    1
        beacon interval:100
        short slot time:yes
        connected time: 10692 seconds
        associated at [boottime]:       40475.747s
        associated at:  1736403476928 ms
        current time:   1736414168942 ms
oh :smiling_face_with_tear:
Perhaps try running this command to turn off power saving for your wireless adaptor. This won’t persist between reboots, it’s just for testing now:
iw wlan0 set power_save off
output was command failed: Operation not permitted (-1)
Then run it as root, ie sudo.
How’d you go @rexx? I see you’ve marked a solution. Has your Minecraft latency improved?
im thinking of just getting a new wifi card
Check for Linux compatibility (goes without saying eh?)
yeah ive researched it
