Menu 11 widget won't work
I installed the menu 11 widget but I can’t use it because an error message always appears when I access it
it says;
file:///home/ari/.local/share/plasma/plasmoids/menu11/contents/ui/main.qml:60:9: Type MenuRepresentation unavailable
file:///home/ari/.local/share/plasma/plasmoids/menu11/contents/ui/MenuRepresentation.qml:137:13: Type MainColumnItem unavailable
file:///home/ari/.local/share/plasma/plasmoids/menu11/contents/ui/MainColumnItem.qml:551:5: Type Footer unavailable
file:///home/ari/.local/share/plasma/plasmoids/menu11/contents/ui/Footer.qml:31:1: module “org.kde.plasma.private.quicklaunch” is not installed
If you don’t have the package kdeplasma-addons installed, you might want to try installing it.
it works, thank you
