I’m not sure what’s going on, because I somehow messed up the log files…
But can you please run a simple command for me, if possible on different kernels that you might have installed?
time perf bench -f simple mem memcpy --nr_loops 100 --size 2GB -f x86-64-movsb
I have seen a large increase that happened some time over the last 3 weeks, and I want to know if it was me who messed up something (highly probable) or a recent kernel update.
Please also report you CPU+RAM configuration.
Thanks
real 0m28.654s
user 0m30.117s
sys 0m0.930s
linux-ck 5.9.2-1-ck
Intel Xeon E3-1225-v3
24 GB RAM
I can reboot into a different kernel if it would help; would you prefer mainline Arch or LTS? Or both?
It’s fine, don’t spend too much time on it.
I’m just trying to debug as I’m not happy with the results…
(22 real seconds here on 3900X - a month ago it was 17 seconds)
real|0m24,220s
user|0m23,322s
sys|0m0,829s
Amd X570-aorus-pro with 3600XT on 16Gb ( DDR3000 )
Not seeing this command working - what is it trying to do? Command not found…
Probably needs some package installed.
I expect so - just don’t know what…
sudo pacman -S perf
Sorry, I thought it came preinstalled.
Ahh - I took a quick look with yay, to see what it might be called - but it might have been part of some other package…
Anyway -
real 0m24.955s
user 0m23.951s
sys 0m0.952s
I still don’t know what it does - but that’s how long it takes!
Oh - and for reference - Ryzen 7 3700x (with a few other things loaded)
Edit: It appears to max out 1 core only, and blip a couple of others near the end…
real |
0m22.877s |
user |
0m21.977s |
sys |
0m0.853s |
Ryzen 3800X
32 GB Memory DDR4 3200 Mhz
MSI X570 Gaming Plus
Zen
real 0m19.821s
user 0m19.354s
sys 0m0.403s
[elloquin@elloquin-elloquin ~]$
Mainline
real 0m24.018s
user 0m22.878s
sys 0m1.077s
LTS
real 0m23.276s
user 0m22.388s
sys 0m0.839s
Makes sense the zen kernel is supposed to have memory optimizations. Clean boot after closing welcome app.
1800x@4.0Ghz 32GB 3200 ram Crosshair VI
A simple memcpy() of 2 GB using movsb instruction, run 100 times
Thanks everyone!
It seems that the results are indeed within normal range.
I will mark this as solved
PS: perf
is a super useful tool for analysing system performance.
perf stat
and perf top
are two further interesting commands.
