Hi,
Today , i tried to install EOS to my ancient macbook pro 13", early 2011, i7, 16G. Holding down the option key i select the EFI Boot and i got the following errors
0.3283491 Initranfs unpacking failed: 2STD-compressed data is corrupt
0.8283441 Failed to execute /init (error -2)
0.8284341 Kernel panic - not syncing: No working init found.
Try passing init= option to
0.8284571 CPU: 2 PID: 1 Conn: swapper/0 Not tainted 6.0.12-arch1-1 #1 c9932778529616caeBbi
0.8284751 Hardware name: Apple Inc. MacBookPro8, 1/Mac-94245B3640C91081, BIOS MBP81.882
0.8284921 Call Trace:
0.8284981
<TASK>
0.8285051
dump_stack_1ul+0×48/0x60
0.8285171
panic+0x11c/0x2c6
0.8285271
? rest _init+0xd0/0xdo
0.8285361 kernel_init+0×130/0×130
0.8285441
ret_from_fork+0x22/0x30
0.8285541
</TASK>
0.8288021 Kernel Offset: 0x2f400000 from OxffffffFf81000000 (relocation range: OxffffffffE
0.8288281
--[ end Kernel panic - not syncing: No working init found.
I tried the manjaro iso with the same usb stick and it boots fine, anyone is familiar with this issue?!
