Hello, I installed the distro on my new Matebook 16, I can see the speaker name on the settings instead of dummy output but I can’t hear nothing. I tried with some headphones and it works well.
That’s the output of aplay and lspci.
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Generic_1 [HD-Audio Generic], device 0: CX11970 Analog [CX11970 Analog]
Subdevices: 1/1
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
Subsystem: Device 1ec9:3e2e
Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
Flags: bus master, fast devsel, latency 0, IRQ -2147483648
Capabilities:
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 0
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: d0600000-d06fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities:
Kernel driver in use: pcieport
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 2
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 3
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: d0500000-d05fffff [size=1M]
Capabilities:
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 4
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 5
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00001000-00001fff [size=4K]
Memory behind bridge: d0100000-d04fffff [size=4M]
Prefetchable memory behind bridge: 000000fce0000000-000000fcf01fffff [size=258M]
Capabilities:
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 43, IOMMU group 6
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: d0000000-d00fffff [size=1M]
Capabilities:
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Flags: 66MHz, medium devsel, IOMMU group 7
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 7
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
Flags: fast devsel, IOMMU group 8
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Subsystem: Electronics & Telecommunications RSH Device 1e25
Flags: bus master, fast devsel, latency 0, IRQ 94, IOMMU group 9
I/O ports at 2000 [size=256]
Memory at d0600000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: rtw_8822ce
Kernel modules: rtw88_8822ce
02:00.0 Non-Volatile memory controller: Sandisk Corp WD Black SN750 / PC SN730 NVMe SSD (prog-if 02 [NVM Express])
Subsystem: Sandisk Corp WD Black SN750 / PC SN730 NVMe SSD
Flags: bus master, fast devsel, latency 0, IRQ 70, NUMA node 0, IOMMU group 10
Memory at d0500000 (64-bit, non-prefetchable) [size=16K]
Memory at d0504000 (64-bit, non-prefetchable) [size=256]
Capabilities:
Kernel driver in use: nvme
Kernel modules: nvme
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne (rev c5) (prog-if 00 [VGA controller])
DeviceName: Realtek RTL8111E Ethernet LOM
Flags: bus master, fast devsel, latency 0, IRQ 57, IOMMU group 11
Memory at fce0000000 (64-bit, prefetchable) [size=256M]
Memory at fcf0000000 (64-bit, prefetchable) [size=2M]
I/O ports at 1000 [size=256]
Memory at d0400000 (32-bit, non-prefetchable) [size=512K]
Capabilities:
Kernel driver in use: amdgpu
Kernel modules: amdgpu
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 91, IOMMU group 12
Memory at d04c8000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
03:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Flags: bus master, fast devsel, latency 0, IRQ 67, IOMMU group 13
Memory at d0300000 (32-bit, non-prefetchable) [size=1M]
Memory at d04cc000 (32-bit, non-prefetchable) [size=8K]
Capabilities:
Kernel driver in use: ccp
Kernel modules: ccp
03:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1 (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 48, IOMMU group 14
Memory at d0100000 (64-bit, non-prefetchable) [size=1M]
Capabilities:
Kernel driver in use: xhci_hcd
03:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1 (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 57, IOMMU group 15
Memory at d0200000 (64-bit, non-prefetchable) [size=1M]
Capabilities:
03:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
Subsystem: Device 1ec9:3e3a
Flags: bus master, fast devsel, latency 0, IRQ 90, IOMMU group 16
Memory at d0480000 (32-bit, non-prefetchable) [size=256K]
Capabilities:
Kernel driver in use: snd_rn_pci_acp3x
Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_sof_amd_renoir
03:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
Subsystem: Device 1ec9:324d
Flags: bus master, fast devsel, latency 0, IRQ 92, IOMMU group 17
Memory at d04c0000 (32-bit, non-prefetchable) [size=32K]
Capabilities:
04:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 45, IOMMU group 18
Memory at d0001000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
Kernel driver in use: ahci
04:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 47, IOMMU group 19
Memory at d0000000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
I hope it can be fixed!
