Manual intervention is required
I updated with pacman -Syu everything was Okay Then I tried yay and there were a couple to upgrade google chrome was one and succeeded the other after 12 hr of running it said it didn’t pass and said electron25-exit status 4. I am not sure what to do ?
Uninstall electron25
sudo pacman -R electron25
removing electron25 breaks dependency ‘electron25’ required by balena-etcher so I removed balena-etcher then I removed electron25 I keep you posted so far it’s seem okay Thanks again
