If you are using Arch but still have the unusual combination of Fish Shell and using flatpaks here is the fix to make the apps show up in your menu of choice (this has nothing to do with Arch as such, this is neccesary to add if you run any DE other than Gnome in any distro if you want flatpak to work properly with fish shell):
Add this to your config.fish:
set -l xdg_data_home $XDG_DATA_HOME ~/.local/share
set -gx --path XDG_DATA_DIRS $xdg_data_home[1]/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
for flatpakdir in ~/.local/share/flatpak/exports/bin /var/lib/flatpak/exports/bin
if test -d $flatpakdir
contains $flatpakdir $PATH; or set -a PATH $flatpakdir
end
end
