LTS Kernel - failed to mount /sysroot
able to update or able to boot on LTS kernel?
able to boot now without failed to mount /sysroot
same here .. does not makes it clearer to me :wink:
Dracut package is updated first of may:
But same for me in general i do not boot on LTS only if i got issue on other 2 i have or like in this case someone reports issue.
i do not think its dracut issue.. i can also boot if i downgrade linux-lts to prior package version.
I see the first post here is one day after the last package update for linux-lts too.
LTS kernel update in:
[2025-05-09T00:57:22+0200] [ALPM] upgraded linux-lts (6.12.26-1 -> 6.12.27-1)
[2025-05-09T00:57:23+0200] [ALPM] upgraded linux-lts-headers (6.12.26-1 -> 6.12.27-1)
working here
I did run yay -S linux-lts and reinstalled the kernel.
this has triggered reinstall-kernels too on sytsemd-boot install.
Would be cool if anyone can validate that it is now booting fine on LTS kernel again?
@joekamprad Nope. Still fails.
EDIT: I did yay to make sure I was fully updated, rebooted into linux-lts 6.12.27-1 and I still get the same failed to mount /sysroot error.
I’m encountering the same issue. It started with linux-lts 6.12.26-1 and continues even after updating to linux-lts 6.12.28-1. After conducting some tests, I discovered that I can successfully boot by restoring my Timeshift backup, which utilizes the lts kernel version 6.12.25-2.
grub
ext4
not encrypted
dracut
EDIT: Thanks to @kq4zj, downgrading to dracut 106 resolved the issue.
I have the same issue with linux-lts 6.12.28.-1
In my case, with systemd-boot, dracut, BTRFS and Luks.
The boot process just stops after I enter the passphrase to decrypt the LUKS partition, it shows a “Waiting for a start job to complete…” and has no time limit. It just stays stuck, and I have to force manually a shutdown.
No problem booting with regular arch and zen kernels.
I just discovered this issue by trying to boot the lts kernel after reading this topic, as usually, I boot with the zen kernel.
Additional question: I just see I have an old /etc/ostree-mkinitcpio.conf file, which is odd as it’s about a long time that I have switched to dracut. I bet I can delete this conf file, right? mkinitcpio is not installed on my system.
I can confirm I just began to get the “failed to mount /sysroot error message”, message after updating.
I can boot using the fallback option (6.12.28-1-lts-fallback) as well as the normal (6.14.5-arch1-1) kernel.
I had the same issue with linux-lts and Dracut,
but after switching to mkinitcpio, it works fine with linux-lts.
Actually, quick update, following the steps here fixed it for me.
I had run reinstall-kernels from the normal kernel before and it did not work, as well as manually reinstalling the kernels via yay. It may have needed to be run from the fallback, or the dracut-rebuild command was what was needed specifically.
So maybe it’s a dracut issue ? Anyway I plan to stay with dracut. @joekamprad wrote he does not think it’s a dracut issue, and I trust his judgment. So for now I’ll wait and see. Thanks for your input.
Thank you, @kq4zj! I resolved the issue by downgrading to dracut 106, which allows me to boot with the latest LTS kernel, 6.12.28-1.
I believe my Timeshift backup from 2025-05-01 16:17:47 (MYT), which includes LTS 6.12.25-2, also has dracut 106. That’s why I’m not experiencing any issues after the restore.
I checked the website to verify the upload date and time of the dracut 107 package. It seems that it was uploaded 6 hours after my backup, assuming the timestamps displayed are in UTC.
Conversion:
  • UTC: 01-May-2025 14:01
  • MYT: 01-May-2025 22:01
    So, 01-May-2025 14:01 UTC is 01-May-2025 22:01 MYT.
Update:
After upgrading to Dracut 107, I booted into the LTS fallback mode and executed the following command:
sudo dracut-rebuild
This resolved the issue.
That file is owned by ostree which is a dependency of flatpak, among few other things.
If you are not using mkinitcpio that file will not be doing anything. However if you remove it, it will be re-installed next time ostree gets updated. I would just leave it there and forget about it.
Confirming still happening after updating LTS just now…
❯ yay
[sudo] password for wombat:
 endeavouros                         13.5 KiB  64.0 KiB/s 00:00 [-----------------------------------] 100%
 core                               117.7 KiB   572 KiB/s 00:00 [-----------------------------------] 100%
 extra                                7.8 MiB  24.5 MiB/s 00:00 [-----------------------------------] 100%
 multilib                           134.5 KiB   676 KiB/s 00:00 [-----------------------------------] 100%
 chaotic-aur                        629.0 KiB   757 KiB/s 00:01 [-----------------------------------] 100%
:: Searching AUR for updates...
:: Searching databases for updates...
 -> Flagged Out Of Date AUR Packages: megasync-bin
:: 6 packages to upgrade/install.
6  core/libgcrypt              1.11.0-3            -> 1.11.1-1
5  core/linux-firmware         20250408.c1a774f3-1 -> 20250508.788aadc8-1
4  core/linux-firmware-whence  20250408.c1a774f3-1 -> 20250508.788aadc8-1
3  core/linux-lts              6.12.27-1           -> 6.12.28-1
2  core/linux-lts-headers      6.12.27-1           -> 6.12.28-1
1  core/man-pages              6.13-1              -> 6.14-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
 -> Excluding packages may cause partial upgrades and break systems
Failed to mount /sysroot error message continues to happen.
Boot into the LTS fallback mode and execute the following command:
sudo dracut-rebuild
This resolved the issue. Thanks to @dalto and @GinGear :slight_smile:
@joekamprad I can confirm that this solution works.
@dirn, that worked. Thanks!
But why? I confirm it works, but how/why/what/where does it work…? No logical reason over a straight dracut-rebuild from another kernel. :exploding_head:
