Hi guys. I’ve been having more or less the same problem. I didn’t know if I should open a new topic or take advantage of this one, sorry about that. It has nothing to do with i3, in my case, because I’ve already tested every possible desktop (for other reasons). I also tried the solution presented here but it doesn’t seem to apply to my case. I have extremely low FPS in games like CSGo and Albion. I’ll put the output of inxi -Fxxxza --no-host
System-Summary
Kernel: 5.16.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=3cc0b1cc-e9dc-41b3-8850-e2ec07c979c9 rw rootflags=subvol=@
quiet loglevel=3 nowatchdog nvme_load=YES nvidia-drm.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, vala-panel
wm: kwin_x11 vt: 7 dm: LightDM 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: MSI model: A320M GRENADE (MS-7A39) v: 2.0
serial: <superuser requiredUEFI-[Legacy]: American Megatrends v: A.40
date: 08/01/2017
Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001126
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1551 high: 2535 min/max: 1550/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1723 2: 2535
3: 1280 4: 1317 5: 1681 6: 2275 7: 1301 8: 1390 9: 1377 10: 1376 11: 1492
12: 1532 13: 1412 14: 1380 15: 1377 16: 1381 bogomips: 95988
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1,HDMI-A-2
empty: DP-1,DVI-D-1 bus-ID: 22:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositors: 1: kwin_x11 2: xfwm
v: 4.16.1 driver: X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 88 s-size: 948x312mm (37.3x12.3")
s-diag: 998mm (39.3")
Monitor-1: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 88
size: 553x311mm (21.8x12.2") diag: 634mm (25")
Monitor-2: HDMI-1 pos: right res: 1366x768 hz: 60 dpi: 80
size: 434x236mm (17.1x9.3") diag: 494mm (19.4")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 22:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 24:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.16.16-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.48 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 1e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 159.9 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filterrev: CC43
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5900 serial: <filterrev: CA12 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD5000AAKX-003CA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filterrev: 1H15
scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: Expansion
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filterrev: 0707 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 107.38 GiB (23.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 512 MiB used: 506.8 MiB (99.0%)
priority: -2 file: /swap/swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 73 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Processes: 406 Uptime: 19h 46m wakeups: 0 Memory: 7.78 GiB
used: 4.37 GiB (56.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1548 lib: 380 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.13
