Hi, newbie here and not a technical person.
My Logitech mouse is preventing the system from staying asleep.
The following permanent solution works, sometimes:
Create new file: /etc/udev/rules.d/logitech.rules
Write the following to file (where 046d is Logitech, c548 is Lift mouse model):
ACTION==“add”, SUBSYSTEM==“usb”, DRIVERS==“usb”, ATTRS{idVendor}==“046d”, ATTRS{idProduct}==“c548”, ATTR{power/wakeup}=“disabled”
Reboot to make it permanent.
This used to work, but now it seems up to chance. I actually found out that it works if I put the system to sleep 3 times in a row (as in: sleep => wakes up; sleep => wakes up; sleep => ok).
I’m excluding other causes because removing the mouse wifi dongle fixes the issue (I can’t help using the dongle for reasons too long to explain here).
Logs: http://ix.io/4CrT http://ix.io/4CrV
You can use a simple script to “unplug” the dongle from the command line, such as one of the solutions suggested in this thread:
Add a script to “unplug” the dongle automatically before suspend to /usr/lib/systemd/system-sleep/, and another to “plug” it back in when your system resumes, as described in this article:
