Using EOS + Gnome 40 for one week, great experience so far.
But I couldn’t figure out how to lock screen.
The Ctrl-Alt-L does not work, neither Super-L.
Do anyone know what’s missing?
Are you using GDM? Only works with GDM.
thank you, that did the trick.
the command to enable is:
sudo systemctl -f enable gdm
It also works with lightdm.
What I did to make this work:
In former times there was a toll called light-locker and a gui tool light-locker-settings to configure. Sadly it does not work any more (for me).
