I don’t know how it is with you, but very often, not always, when KDE releases a new major version update, my locale settings are messed up and it is the same issue over and over again. I know how to fix it, I mean it comes up so often I know the command by heart, which isn’t a good thing in this case.
I have had this issue on Plasma for some time now and on different hardware. Do you have a permanent solution or am I one of the rare users who encounter this issue almost on a regular schedule?
If I change my locale via KDE System Settings, for some reason LC_ALL becomes blank, which causes startup failure on some applications. This also breaks os-prober for some reason
It has to do with some Plasma updates and after restoring it, it’s all fine. It’s a bit annoying.
I don’t know if you remember, but a couple of months ago I had this issue not being able to change the name whilst downloading a PDF, which you also solved and turned out to be a Plasma thing as well? That bug returned after the latest Plasma update.
I fixed it, but to be honest I don’t like how Plasma handles major updates. I will not ditch it though, but I find the overriding settings after an update a bit annoying.
Yes, but when the issue arises, there’s a typo in one or more of the lines. It shows up after an update as:
