I installed linux-lts plus headers via akm, lts boots into emergency shell- what did i do wrong and how do i fix it?
pacman -Q linux linux-lts
linux 5.10.16.arch1-1
linux-lts 5.10.17-1
linux-lts 5.10.17-1
We need some logs (e.g. journal) to see the actual problem. Please take a look at: https://endeavouros.com/docs/forum/how-to-include-systemlogs-in-your-post/
There is no log for the boot attempt in question, and the keyboard is dead in the emergency shell.
All i have is a friggin photo:
Does linux
boot?
That looks like it might be an initramfs problem.
Can we see the contents of /etc/mkinitcpio.conf
Yes, it does.
It is odd having linux and linux-lts in the the same kernel branch.
mkinitcpio.conf:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS="base udev autodetect keyboard keymap consolefont modconf block lvm2 filesystems fsck"
## This setup will autodetect all modules for your system and should
## work as a sane default
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
## This setup loads an lvm2 volume group on a usb device.
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
What is the output of:
sudo mkinitcpio -p linux-lts
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'default'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts.img
==> Starting build: 5.10.17-1-lts
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [filesystems]
-> Running build hook: [fsck]
==> Generating module dependencies
==> Creating xz-compressed initcpio image: /boot/initramfs-linux-lts.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'fallback'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: aic94xx
==> Creating xz-compressed initcpio image: /boot/initramfs-linux-lts-fallback.img
Does it still fail to boot the lts kernel?
Still fails, yes.
I just found i have exactly the same behaviour on arch, only difference is the manual kernel installation and nvidia non-dkms.
Let’s close this thread, i guess/hope it is an issue which will disappear as soon as the arch stable linux package is on 5.11
Should have tried that before, sorry.
Closed per request. Let us know if we need to re-open it in the future.
