Lightdm-slick-greeter settings
Since lightdm-slick-greeter is the default greeter in the latest isos, I assume we need to install the lightdm-settings package from the AUR to change the appearance, … etc, is that correct?
You should be able to use that tool if that is your preference.
Alternatively, you could just edit the config file.
Ok, that’s what I’ve found on linuxmint’s github page. Thanks for the reply!
