Dev0ut
August 4, 2021, 8:24am
21
Create/open a new file with sudo xed /etc/X11/xorg.conf.d/20-nvidia.conf
and paste this
Section "Device"
Identifier "Nvidia Card"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce RTX 2070"
Option "Coolbits" "24"
EndSection
After that delete / backup /etc/X11/xorg.conf
file
then
Reboot and post inxi -Gx
Dev0ut
August 4, 2021, 8:31am
22
If that doesn’t work then sudo xed /etc/default/grub
to open the grub configuration file and add to the line GRUB_CMDLINE_LINUX_DEFAULT="
these parameters after the stuff that already is there nvidia nvidia-drm.modeset=1 nvidia_modeset nvidia_uvm nvidia_drm
, be sure that they are enclosed inside ""
After that sudo grub-mkconfig -o /boot/grub/grub.cfg
and reboot
inxi -Gx
after reboot as always
Ok I will try the step with grub, because now xorg take half of my CPU usage and I just scrolling webpage.
btw create new file nvidia.conf and delete xorg doesn’t work.
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI driver: nvidia v: 470.57.02 bus-ID: 26:00.0
Device-2: Microdia Dual Mode Camera (8006 VGA) type: USB driver: hid-generic,usbhid bus-ID: 5-2:3
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting failed: nvidia resolution: 3440x1440~100Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.1 256 bits) v: 4.5 Mesa 21.1.6 direct render: Yes
Dev0ut
August 4, 2021, 9:00am
24
Yeah, you’re using CPU rendering with a 3k resolution xD
Yea right what a shame still nothing
probably stay with gdm here is inxi -Gx from it
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution: 3440x1440~100Hz
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Dev0ut
August 4, 2021, 9:20am
26
Yeah, with gdm your driver is loaded correctly! Weird, the lightdm has the logind-check-graphical=true
parameter
Yep I uncomnent this in /etc/lightdm/lightdm.conf
# guest-account-script = Script to be run to setup guest account
logind-check-graphical =true
# log-directory = Directory to log information to
Dev0ut
August 4, 2021, 9:30am
28
it has unnecessary spaces, it should look like this :
Nice try but no changes even when I remove space
Also try LTS kernel linux-lts 5.10 but nothing.
