I’m using i3 and I’m not sure if it’s related but I have a line in my config file to execute polkit-gnome-authentication-agent-1 as i3 launches.
Here’s the error message when I run liferea :
(liferea:134390): libsecret-CRITICAL **: 19:12:28.222: secret_service_load_collections_sync: assertion 'paths != NULL' failed
File "/usr/lib/liferea/plugins/gnome-keyring.py", line 52, in do_query
coll = self.get_collection()
File "/usr/lib/liferea/plugins/gnome-keyring.py", line 42, in get_collection
colls = service.get_collections()
AttributeError: 'NoneType' object has no attribute 'get_collections'
(liferea:134390): libsecret-CRITICAL **: 19:12:28.225: secret_service_load_collections_sync: assertion 'paths != NULL' failed
Segmentation fault (core dumped)
heres my system info :
Kernel: 6.2.6-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=c2175524-d6d2-46b9-b643-3398c4a67189 rw
resume=UUID=1ebf9c59-e903-401d-aebf-1e7428ac4939 loglevel=3 nowatchdog
nvme_load=YES nvidia-drm.modeset=1
Desktop: i3 v: 4.22 info: polybar vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Gigabyte model: X58A-UD3R serial: <superuser required>
BIOS: Award v: FB date: 08/24/2010
Battery:
Message: No system battery data found. Is one present?
Memory:
RAM: total: 23.47 GiB used: 5.79 GiB (24.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
Info: model: Intel Core i7 950 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1A (26) stepping: 5 microcode: 0x1D
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1607 high: 1619 min/max: 1596/3060 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1619 2: 1596
3: 1596 4: 1596 5: 1619 6: 1596 7: 1619 8: 1618 bogomips: 49679
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Type: mmio_stale_data status: Unknown: No mitigations
prctl
sanitization
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none off: DP-1,HDMI-A-1 empty: DVI-D-1,DVI-I-1
bus-ID: 03:00.0 chip-ID: 10de:1401 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-b700a driver:
X: loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
s-diag: 610mm (24")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary
model: Idek Iiyama PL2483H serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled model: LG (GoldStar) TV
serial: <filter> built: 2010 res: 1920x1080 dpi: 305 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes:
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX
960/PCIe/SSE2 direct-render: Yes
Device-1: Intel 82801JI HD Audio vendor: Gigabyte GA-EP45-DS5/GA-EG45M-DS2H
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 10de:0fba class-ID: 0403
Device-3: Creative Labs EMU20k2 [Sound Blaster X-Fi Titanium Series]
driver: snd_ctxfi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 1102:000b class-ID: 0403
Sound API: ALSA v: k6.2.6-arch1-1 running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.67 running: yes
vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: ee00 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
WAN IP: <filter>
Bluetooth:
Message: No bluetooth data found.
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Local Storage: total: 11.33 TiB used: 10.03 TiB (88.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 054 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS723020BLA642
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A580 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R013 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT240BX500SSD1
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Seagate model: Basic
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0712 scheme: MBR
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital
model: WD5000AAVS-22G9B1 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: <unknown> type: N/A serial: <filter> rev: 1.75
scheme: MBR
ID-7: /dev/sdg maj-min: 8:96 type: USB vendor: Samsung
model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: <unknown> type: HDD rpm: 5400 serial: <filter>
rev: 0608 scheme: MBR
ID-8: /dev/sdh maj-min: 8:112 type: USB vendor: Toshiba model: MQ04UBD200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: HDD rpm: 5400
serial: <filter> scheme: MBR
ID-9: /dev/sdi maj-min: 8:128 type: USB vendor: Toshiba model: EXTERNAL USB
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 5438 scheme: GPT
Message: No optical or floppy data found.
ID-1: / raw-size: 421.31 GiB size: 413.62 GiB (98.18%)
used: 333.4 GiB (80.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: c2175524-d6d2-46b9-b643-3398c4a67189
ID-2: /mnt/CRUCIAL SSD 240 GB raw-size: 223.57 GiB
size: 223.57 GiB (100.00%) used: 558.5 MiB (0.2%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: CRUCIAL SSD 240 GB uuid: 60CED6A12CD2DF87
ID-3: /mnt/CRUCIAL SSD 240 GB 2 raw-size: 223.57 GiB
size: 223.57 GiB (100.00%) used: 71.5 MiB (0.0%) fs: ntfs dev: /dev/sdd1
maj-min: 8:49 label: CRUCIAL SSD 240 GB 2 uuid: 5F16B74A1E2AD178
ID-4: /run/media/gregoire/940b2794-d0ee-47c4-bebf-55d9874f0dc9
raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.69 TiB (94.6%) fs: ext4
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 940b2794-d0ee-47c4-bebf-55d9874f0dc9
ID-5: /run/media/gregoire/My Book raw-size: 465.75 GiB
size: 465.64 GiB (99.98%) used: 457.48 GiB (98.2%) fs: vfat dev: /dev/sdf1
maj-min: 8:81 label: My Book uuid: 6F24-25FD
ID-6: /run/media/gregoire/Seagate Expansion Drive raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 903 GiB (96.9%) fs: ntfs dev: /dev/sdg1
maj-min: 8:97 label: Seagate Expansion Drive uuid: F078AA3D78AA0288
ID-7: /run/media/gregoire/TOSHIBA EXT raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.56 TiB (85.6%) fs: ntfs dev: /dev/sdh1
maj-min: 8:113 label: TOSHIBA EXT uuid: 182C876D2C87452A
ID-8: /run/media/gregoire/TOSHIBA EXT1 raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 3.58 TiB (98.5%) fs: ntfs dev: /dev/sdi2
maj-min: 8:130 label: TOSHIBA EXT uuid: 822224A222249D63
ID-9: /run/media/gregoire/fa9219f2-996e-4f53-973b-683773a8608b
raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.54 TiB (86.0%) fs: ext4
dev: /dev/sde2 maj-min: 8:66 label: N/A
uuid: fa9219f2-996e-4f53-973b-683773a8608b
Unmounted:
ID-1: /dev/sda2 maj-min: 8:2 size: 25.82 GiB fs: swap label: swap
uuid: 1ebf9c59-e903-401d-aebf-1e7428ac4939
ID-2: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: ntfs
label: R\xc3\xa9serv\xc3\xa9 au syst\xc3\xa8me uuid: 866467A1646792AB
ID-3: /dev/sdi1 maj-min: 8:129 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
USB:
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 1-2:2 info: Logitech Mouse type: Mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 046d:c077
class-ID: 0301
Hub-2: 2-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 2-1:2 info: Western Digital My Book Essential Edition 2.0 (WDH1U)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 2mA chip-ID: 1058:1100 class-ID: 0806 serial: <filter>
Device-2: 2-4:4 info: Seagate RSS LLC Basic type: Mass Storage driver: uas
interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 0bc2:aa15
Hub-3: 3-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2:2 info: Seagate RSS LLC USB 3.0 bridge [Portable Expansion
Drive] type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 0bc2:2320 class-ID: 0806
serial: <filter>
Hub-4: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 5-2:2 info: Logitech Washable Keyboard K310 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 98mA
chip-ID: 046d:c326 class-ID: 0300
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 8-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-9: 9-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-10: 10-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 10-1:2 info: Toshiba America EXTERNAL_USB type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:0901 class-ID: 0806 serial: <filter>
Device-2: 10-2:3 info: Toshiba America MQ04UBF100 type: Mass Storage
chip-ID: 0480:0900 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Processes: 295 Uptime: 3h 41m wakeups: 0 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1609 libs: 405 tools: yay pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
Thanks for the help.
