Librewolf Rebuild Issue
I just update the system and saw that librewolf-bin needed rebuilt. So I double checked.
❯ checkrebuild
foreign	librewolf-bin
I then ran yay -S librewolf-bin --rebuild and got the following after successful rebuild…
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating icon theme caches...
(3/4) Checking which packages need to be rebuilt
(4/4) Updating the desktop file MIME type cache...
I seem to be in a rebuild loop. Anyone have ann idea as to why this might be happening?
I am not sure why rebuild-detector is flagging that but rebuilding a *-bin package seems pointless to begin with.
Run checkrebuild -v and share the output.
EDIT: Nevermind, I checked. That is fine you can ignore it.
❯ checkrebuild -v
ldd /usr/lib/librewolf/gmp-clearkey/0.1/libclearkey.so
	libmozsqlite3.so => not found
:thinking:
There is nothing you can do about that. It will probably stop showing up next time it is updated.
In general, there is nothing you can do when rebuild-detector flags a binary package.
