Libreoffice-fresh bug
In libreoffice-fresh writer “insert from a file” (“inserer depuis un fichier”) does not work : nothing is inserted.
Did you mean “Insert → Text from file…”?
Never needed it before. :wink: But I can reproduce the issue…with LibO 6.3.4.1 from libreoffice.org on siduction. :wink:
At .txt: “Read Error: Error reading file.” (Bullshit.)
With .odt apparently nothing happens.
Inserting an image as a file happens without any problems.
I guess you’ll have to go over c&p. And create a bug report if there isn’t one yet.
Yes “insert -> Text from file” (sorry)
I go to verify in libreoffice bugs.
Here is the result of insert "text from file" query in LibreOffice bug tracker:
https://bugs.documentfoundation.org/buglist.cgi?bug_status=UNCONFIRMED&bug_status=NEW&bug_status=ASSIGNED&bug_status=REOPENED&bug_status=NEEDINFO&field0-0-0=product&field0-0-1=component&field0-0-2=alias&field0-0-3=short_desc&field0-0-4=status_whiteboard&field0-0-5=content&field1-0-0=product&field1-0-1=component&field1-0-2=alias&field1-0-3=short_desc&field1-0-4=status_whiteboard&field1-0-5=content&no_redirect=1&order=changeddate%2Cpriority%2Cbug_severity&query_format=advanced&type0-0-0=substring&type0-0-1=substring&type0-0-2=substring&type0-0-3=substring&type0-0-4=substring&type0-0-5=matches&type1-0-0=substring&type1-0-1=substring&type1-0-2=substring&type1-0-3=substring&type1-0-4=substring&type1-0-5=matches&value0-0-0=insert&value0-0-1=insert&value0-0-2=insert&value0-0-3=insert&value0-0-4=insert&value0-0-5="insert"&value1-0-0=text%20from%20file&value1-0-1=text%20from%20file&value1-0-2=text%20from%20file&value1-0-3=text%20from%20file&value1-0-4=text%20from%20file&value1-0-5="text%20from%20file"
Capture%20du%202019-11-30%2008-27-59
Not a lot of answers, indeed.
https://bugs.documentfoundation.org/show_bug.cgi?id=129091
Closed as duplicate of this bug: https://bugs.documentfoundation.org/show_bug.cgi?id=129082
If I understand what is going on, this bug is going to be an old story for next 6.3.x release.
https://bugs.documentfoundation.org/show_bug.cgi?id=129082#c6
