Yes, for the most part. I have nagging non-updates I think due to the fact the projects are no longer update:
:: Searching databases for updates...
:: Searching AUR for updates...
-> Missing AUR Packages: clonezilla-experimental grub-tools grub2-theme-endeavouros ipw2100-fw ipw2200-fw kvirtual-git progsreiserfs
-> Missing AUR Debug Packages: libkipi-debug
-> Orphaned AUR Packages: gweled kdelibs libdbusmenu-qt4 libguess perl-gtk2-ex-simple-list wxcommon-dev-light wxgtk3-dev-light
-> Flagged Out Of Date AUR Packages: freegemas libkipi perl-gtk2-ex-simple-list python-pluginbase soundkonverter-frameworks-git wxcommon-dev-light wxgtk3-dev-light
:: 2 Packages to upgrade.
2 aur/python-node-semver 0.8.1-1 -> 0.8.1-2
1 aur/tenacity-wxgtk3-git r13926.g0665614b8-2 -> r14126.gef91e7c8d-4
I’m not sure if that would be part of the problem. I tried manually updating them one by one but to no success.
You could remove all cached packages whether installed or uninstalled with
sudo pacman -Scc
Also which version of libreoffice are you trying to install? There is libreoffice-fresh and libreoffice-still
Edit: Sorry i see above libreoffice-fresh.
ricklinux:
sudo pacman -Scc
I’m ready to try still
That didn’t work either.
I checked and the /var/lib/pacman/local/libreoffice-fresh-7.4.3-3/ no longer exists.
Well like @pebcak say’s you need to run the install for libreoffice-fresh and post the output.
Can you give me the prompt on how to do this using privatebin or pastebin? Sorry, I’m not finding it. Thanks
I’m not sure what will happen if it fails whether it will post the output?
sudo pacman -S libreoffice-fresh | eos-sendlog
Edit: Should provide a link.
Darn, I remember the pipe sign but I couldn’t make out the where to send it with
https://0x0.st/onf1.txt
I can’t paste it all ikn here.
Thanks
I think if it were me i would delete the folder libreoffice with all files in /usr/lib
manuel
December 14, 2022, 4:49pm
29
How about
sudo pacman -S libreoffice-fresh --overwrite '*'
Bold, I was going to suggest that but thought it would be bad. Doing it now. I have to remove the files one by one using the terminal. I don’t think there is a way to remove an entire directory. Not sure if this is a safety thing or I don’t know.
Thanks
Better to try what @manuel posted above.
Thanks Manuel,
It says: “option ‘–overwrite’ requires an argument”
manuel
December 14, 2022, 4:59pm
33
Please copy the full line.
LOL!
Manuel gets the gold star today! It worked.
Thank you everyone for your kind help!
You should be marking post #29 as the solution not your own post.
Thanks. It’s been one of those days, weeks, months, etc…
system
Closed
December 16, 2022, 5:29pm
37
