Libelf 0.195-1 breaks dependency libelf=0.194 required by lib32-libelf
I am getting the following error while trying to update:
:: installing libelf (0.195-1) breaks dependency 'libelf=0.194' required by lib32-libelf
I have no testing repositories enabled in pacman.conf
thanks!
hey! Welcome back! Perhaps stating the obvious, but does this happen when running
sudo pacman -Syyu ?
Do you have the multilib repo enabled in pacman.conf?
yes, but not the testing ones
[endeavouros]
SigLevel = PackageRequired
Include = /etc/pacman.d/endeavouros-mirrorlist
#[core-testing]
#Include = /etc/pacman.d/mirrorlist
[core]
#[extra-testing]
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
#[multilib-testing]
[multilib]
lib32-libelf was updated a little bit later than libelf, so there was a short period those two were out of sync. Should be fine now.
this made it!
sorry for not trying it before posting.
Formerly, I was just updating with yay
