Output from pacman:
ldconfig: File /usr/lib/libKF5Attica.so.5 is empty, not checked.
ldconfig: /usr/lib/libxatracker.so.2 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: file /usr/lib/libLLVM.so is truncated
ldconfig: /usr/lib/libxatracker.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libKF5Attica.so is empty, not checked.
ldconfig: File /usr/lib/libproxy.so.1 is empty, not checked.
ldconfig: file /usr/lib/libLLVM-13.so is truncated
ldconfig: file /usr/lib/libgo.so.19 is truncated
ldconfig: file /usr/lib/libgo.so.19.0.0 is truncated
ldconfig: File /usr/lib/libproxy.so is empty, not checked.
ldconfig: File /usr/lib/libproxy.so.1.0.0 is empty, not checked.
ldconfig: /usr/lib/libxatracker.so.2.5.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: file /usr/lib/libLLVM-13.0.0.so is truncated
ldconfig: File /usr/lib/libKF5Attica.so.5.89.0 is empty, not checked.
ldconfig: file /usr/lib/libgo.so is truncated
ldconfig
> sudo ldconfig
How can I solve this issue?
