┌─[user@Dell-Latitude]─[~]
└──╼ $sudo pacman -R broadcom-wl-dkms
[sudo] password for user:
checking dependencies...
Package (1) Old Version Net Change
broadcom-wl-dkms 6.30.223.271-35 -7.61 MiB
Total Removed Size: 7.61 MiB
:: Do you want to remove these packages? [Y/n] y
:: Running pre-transaction hooks...
(1/1) Remove DKMS modules
==> dkms remove --no-depmod broadcom-wl/6.30.223.271 -k 5.15.77-1-lts
==> dkms remove --no-depmod broadcom-wl/6.30.223.271 -k 5.19.13-arch1-1
==> dkms remove --no-depmod broadcom-wl/6.30.223.271 -k 6.0.7-1-clear
==> dkms remove --no-depmod broadcom-wl/6.30.223.271 -k 6.0.7-arch1-1
==> dkms remove broadcom-wl/6.30.223.271
==> depmod 6.0.7-arch1-1
==> depmod 5.15.77-1-lts
==> depmod 6.0.7-1-clear
==> depmod 5.19.13-arch1-1
depmod: WARNING: could not open modules.order at /lib/modules/5.19.13-arch1-1: No such file or directory
depmod: WARNING: could not open modules.builtin at /lib/modules/5.19.13-arch1-1: No such file or directory
depmod: WARNING: could not open modules.builtin.modinfo at /lib/modules/5.19.13-arch1-1: No such file or directory
:: Processing package changes...
(1/1) removing broadcom-wl-dkms [----------------------] 100%
(1/1) Arming ConditionNeedsUpdate...
I don’t know. I’m far from an expert also and yes i do know the clear linux kernel is optimized for Intel hardware but there are others who have this same Intel Ethernet and WiFi. I haven’t seen this issue before.
The only other thing I can think of is that I had installed endeavouros without checking a box, it was called ‘endeavouros tweaks’ or ‘endeavouros themes’ something like that.
You have Intel Ethernet and Wifi which should both be well supported. Is there a time frame for when the Kernel Panic started?
I know in most router configurations even for Intel NICs you want to disable hardware checksum offload, hardware TCP segmentation offload, and hardware large receive offload to avoid this sort of issue.
Ive also heard of that NIC having some issues with C states but I honestly cant be sure whats going on here. Im guessing its either firmware or related to hardware offloading which is the usual case for this sort of thing when Ive encountered it.
Usually this happens with Realtek NICs and not intel though
