Operating System: EndeavourOS
KDE Plasma Version: 5.21.0
KDE Frameworks Version: 5.79.0
Qt Version: 5.15.2
Kernel Version: 5.10.16-zen1-1-zen
OS Type: 64-bit
Graphics Platform: X11
Processors: 8 × AMD FX™-8350 Eight-Core Processor
Memory: 15.6 GiB of RAM
Graphics Processor: GeForce GT 630/PCIe/SSE2
using KDE Plasma with LightDM
after today’s update my system freezes completely, for the first time after the uddate reboot I was not able to login (keyboard & mouse hungs) then always after about 5 minutes the system freezes.
I had to perform a hard reset, the keyboard and mouse could no longer be moved there was no error screen system just froze, tested w/ both new kernels zen & default
so I have restored the previous system (from above) via timeshift
That is a problem I’ve noted with the combo of lightdm and wayland WMs (like sway and plasma_wayland). Just not a good combo (imo), though I like lightdm itself.
And yes, my problem is also keyboard/mouse under those circumstances.
Solution: use SDDM or simply invoke from shell (without a display manager)
yeah, there seems to be an issue with the new kernel linux-5.11.1 arch and the same with linux-zen-5.11.1 …
I use nvidia-dkms and virtualbox-dkms, when I skip the kernel updates the system does not freeze
KDE Plasma Version: 5.21.1
Qt Version: 5.15.2
Kernel Version: 5.10.19-1-lts
OS Type: 64-bit
The freezing problem persists, it seems the 5.11.1 kernel is not yet stable, so I installed LTS a few days ago and it worked.
after yesterday’s update another kernel problem apparently occurred with 5.10.19-1 and light-dm
if i start the system and the idle state is triggered (after long wait) then the system no longer wakes up
so I switched from light-dm to sddm, so far it works … with sddm it shows following in journal:
