I am so close to moving to Endeavour OS from my Ubuntu 22.04 install on my laptop. And thank you again to everyone who has helped me and answered my silly questions. I am trying to just double-check a few last things so that I do not lose too much productivity time after I make the switch.
Currently in my Ubuntu install I have 3 bash scripts I created that I use for quickly converting some file types that I use in my work on a regular basis. They are in my home folder under /home/ME/.local/share/nautilus/scripts
When I right click on a file, I have a menu item called Scripts and that expands to show my three bash scripts so I can run one against a given file. Is there something like this in KDE Plasma (or in Dolphin)? I love that I can create these scripts and drop them in the folder and they automatically show up in the right click menu. I tried Googling this and could not seem to find a clear (or understandable for me) answer.
If I can figure this out I will only have one or two things left to figure out and can then make the switch to Endeavour OS. I cannot remember what one of those things was, but I am hoping I will in the next few hours, lol. Not enough coffee yet today, but really is there any amount of coffee that is truly enough? I am so excited to be this close to making the switch and am hoping I can maybe do it Sunday evening or Monday morning. Thank you again for all of your help and putting up with my questions. This community is awesome and I am looking forward to becoming part of it. Hopefully one day I will know enough to be able to help others the way you have all helped me.
Okay, that helps a lot. So can I have the .desktop execute the bash script, or do I move the bash script into the .desktop file? For instance, this is one of the bash scripts I use:
#!/bin/bash
for fullpath in "$@"
do
filename="${fullpath##*/}" # Strip longest match of */ from start
dir="${fullpath:0:${#fullpath} - ${#filename}}" # Substring from 0 thru pos of filename
base="${filename%.[^.]*}" # Strip shortest match of . plus at least one non-dot char from end
ext="${filename:${#base} + 1}" # Substring from len of base thru end
if [[ -z "$base" && -n "$ext" ]]; then # If we have an extension and no base, it's really the base
base=".$ext"
ext=""
#newdir=/"$base"/"$base"
fi
printf 'Creating directory\n' >> log
mkdir $base || exit
printf 'Converting PDF to PNGs\n' >> log
printf "$filename /$base/$base\n" >> log
pdftoppm -png "$filename" "./$base/$base"
printf 'All done\n\n' >> log
done
